Won't read any cd
Won't read any cd? Not even a store bought cd?
Remove the Power Cord, Remove the Battery, turn the laptop over and remove the one screw that holds the cd drive in place and pull the cd drive out then put it back in. Reboot and see if it's ok.
Click Start/My Computer and see if your cd drive is listed as a device. If not you will need to remove Upper & Lower Filters.
http://support.microsoft.com/kb/314060
Remove Upper and Lower FiltersWindows 7
To resolve this problem on a computer that is runningWindows 7, use the Hardware and Devices troubleshooter. For more informationabout how to open this troubleshooter in Windows 7, visit the followingMicrosoft Web site:http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooterBack to the topWindows Vista
, and then click All Programs.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Now go to the "Did this fix theproblem?" section.Back to the topWindows XP
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
SOURCE: iam getting no sound card error for dell inspiron
Probably your Audio Driver isn't proper or isn't installed.
Here's the Audio driver that I'm using under Windows XP
I hop this will help you out,
Regards, WAQAR.
SOURCE: dell inspiron e1505 problem with error code 39 for
Hi, check my article to fix the issue..
http://www.fixya.com/support/r3579304-how_to_fix_cddvd_rom_error_code_39
SOURCE: Getting error code 2000-0146 on my computer
i have a error code 2000-0146. is there a solution to this besides replacing the hard drive. can data files be safed??
SOURCE: Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
SOURCE: i have a dell inspiron
The disk-drive that is your 'C:' drive has malfunctioned.
So, the copy of Microsoft Windows stored on that disk-drive cannot be loaded.
Take your computer, and the set of "System Restore" CD/DVD disks, to a computer-store. You'll need to buy a new disk-drive, and to reinstall Windows onto the new disk-drive.
