I see the camera in device and printers but i cant have possibilities to download the pictures storage on the memory card. What can i do? I try i guess all posibillities.
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Try putting the card in the camera and in the menu, select 'FORMAT' this will totally wipe the memory card, ready for use. You will find plenty replacement cables on Ebay, for about £7.00-8.00
SOURCE: Cant find how to clear memory card in digital camera.
If you want to delete files / pictures on memory card then unplug your camera from PC and press Menu on camera, go to format option and format memory card.
All files on memory card will be deleted.
Or right click on Cybershot software icon in icon tray (right lower corner of monitor) and check settings, required window option can be enable by putting check mark.
SOURCE: Cant download pictures to my computer....
TRY RESTORING YOUR PC TO A TIME BEFORE THIS STARTED, OR COULD BE YOUR FIREWALLS
SOURCE: file error
It is picture file that stops file transfer function, delete that picture and continue or go to memory card through my computer > mass storage drive and delete that file or copy rest of files and past in computer some where like my documents etc.
That particular picture file DSC03270.jpg is incomplete/ corrupted and causing problem in files transfer operation. Either delete it or bypass it and transfer rest of files from camera.
After transferring files to computer, format memory card to avoid any problem in next time as option would be in camera menu.
Let me know if you have additional question.
Thanks.
