Question about NEC Televison & Video
I have A problem connecting USB to a Nu-Tec TV 1958 18.5.
I need help connecting my USB to my Nu-Tec TV NUE 1958. The screen only displays Can't detect device does anyone know how to Connect The USB
timwicks
    New Friend:
As suggested by Geoff I called the help centre. They informed that the usb input for the 18.5" model is not for hdd input, that it is for technicians to add firmware updates etc
Posted on Jun 19, 2012
4 Related Answers
Anonymous
SOURCE: Does anyone know where to get NU-TEC LCD TV Parts
For all inquiries Nutec LCD TV's in Australia below are the details.
Contact Yale Prima PTY LTD
Ph: 1300366155
Between 9am & 5pm AEST (Australian Eastern Standard Time)
Regards
Geoff
Posted on Jun 01, 2010
Anonymous
SOURCE: cannot tune channels eg channel
i had same prob untill i pluged it into a wall antana went auto setup australia DTV only and i got 7, 73 ,70, 71 , 90, 99,9,10,1,11, when pluged into a portable tv antana i lost 7, 73 ,70, 71 so that how i fixed my problem
Posted on Jan 08, 2011
Mon_ica
SOURCE: i have purchased a Nu-Tec
I have the same problem. Have you worked out how to make it work??
Posted on Oct 02, 2011
Jennifer Helms
  • 78 Answers
SOURCE: need code/tv-nu tec/universal one for all
Universal One-For-All Remotes actually have a website that you can get the codes from! I have this same remote & just googled it.
Posted on Feb 29, 2012
My nu-tec tv model nue 1992 has no sound, I cannot find "setup", and all instruction are in German. Where do I go from here???
suggest learning german . Gutten Targ Hier Warren.
On a more practical note !
There are German to English translator web sites try using these to at least be able to understand the German on the screen.
I did try searching for a user munaul but Nu-tech is such a popular company name for many companies to use which makes it very hard to find a user manual.
http://translation.babylon.com/german/to-english/
Here is a test for you to translate
Hier ist ein Test f?r sie Warren. Ich bin nicht Deutsche skeak meine Schwester einen deutschen Mann geheiratet und auch fliessend deutsch spricht. Meine Frau gerade gekauft ein Geschenk zu Weihnachten von einer deutschen Website als das Porto teuer ist, Deutschland aus Australien. Meine Frau wei? nicht ein Wort Deutsch, das war also fertig mit einem Deutschen auf Englisch ?bersetzer vor Ort.
Jan 02, 2015 | Televison & Video
Nu-Tec n126 forgot parental code
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Jun 27, 2017 | Televison & Video
Bw7080 remote to a nu-tec tv & dvd comb
Just buy one universal remote control, which have setup codes for your brand combo. You can get this detail by the code list accompanied with the remote control. Brand isn't matter.
Apr 30, 2012 | Televison & Video
I just bought a nu tec tv and it won't tune into any stations please help
T uner of signal module needs replace. Check and see if you have signal going to your video input.
Apr 09, 2012 | Televison & Video
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
Cannot tune channels eg channel 9 10 7 only gets sbs abc nu-tec mod NUE 1958 18.5 " lcd
Jan 06, 2011 | Televison & Video
Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital antener. all works but I can't get any channel 9 stations no matter how many times I rescan channels?
''Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital ''
Poor English!
It should read; ''Bought a Coles $259 Nu-tec DVD/Tv combo, brought it home and set it up with a indoor digital ......''
Jun 12, 2010 | Televison & Video
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Mar 31, 2008 | Hotpoint RVM1625 Microwave Oven
Televison & Video Logo
783 people viewed this question
Top NEC Televison & Video Experts
Marvin
Marvin
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
