Question about Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM
What's your problem?I recently purchased a used turbo air MSF-49nm freezer. It cooled down from room temp to -7 in less than 45 minutes. Problem is that it cycles and temp immediately starts risin
I have checked coils for dirt and they re ok, raised temp set point from -5 to 0 but same issue.
Posted by G Murphy on
  • 4 more comments
  • mike cooper Apr 14, 2012
    Has the sensor/ thermostat been displaced?
  • G Murphy Apr 14, 2012
    Displaced? Please elaborate.
    Mike, I do not know what you mean by displaced, did you mean replaced? If not tell how to check please.
    THe freezer appears to go into automatic defrost properly, freezes like a champ and does not leak anything on the floor.
  • G Murphy Apr 17, 2012
    I have noticed that the compressor also runs during defrost cycle. When auto defrost kicks in the compressor also comes on for the full cycle.
  • mike cooper Apr 20, 2012
    I meant had the sensor end become detached from the fixing. However if it had it would be running longer, not shorter. What settings are on the control? Can you set the setpoint to lower than -5, e.g to -21?
mike cooper
  • 884 Answers
The compressor runs during defrost to supply hot gas to the inside coil
Posted on Apr 20, 2012
The compressor stop at 58
Change the temperature control.
http://www.acmehowto.com/howto/appliance/freezer/repair/tempcontrol.php
Dec 13, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Turbo air frz goes into defrost compressor continous to run. Does not stop during defrot
Hi, Please set your thermostat a bit warm and observe the compressor. Also check your freezer for leaking.
Nov 06, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Sep 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
I need a manual for maximum freezer
http://www.turboairinc.com/TB-Service/Service.html#SOLID_DOOR_REACH-IN
Since I do not have the exact model number, here is the site you need to visit to get the manual. Hope this is what you are looking for.
Jan 23, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Msf-49nm will not stay below freezing!!
My next question is, you say you have to call a tech to come out. Is he doing something? And if so, what? With the limited info I have at this time, it sounds like there may be a refrigerant problem. Let me know so we can continue. Am looking forward to resolving this.
Jun 02, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Msf-49nm evaportor pan and drain iced up
I deal with MasterBilt which is a private lable made by TurboAir.
I have several units but only one does this icing up thing. Look for a bad seal on the door gasket. These really ice up if that does not seal almost perfectly. Look for premature termination of the defrost cycle. Check that the heater is pulling amps. The wiring diagram at "turboairinc.com" is very poor but it shows 2 heaters for the refrigerator. They list a diagram for the freezer but it's not there. I know for sure that there is a heater for the evap but don't know about the drain. I've seen some have it and some don't. there tech support line has much to be desired but it's worth a shot. Also, the bottom hinge on the door fails fairly regularly. This allows the door to drop just enought to disengage the switch at the top of the door and stop the evap fan from running, thus causing a freeze up.
Good Luck . You got your hands full with this one.
Dec 11, 2008 | Turbo Air 49 cu. ft. / 1388 liter...
Set tempature on minus 5 unit doen't shot down runs all the time.
It sounds to me very likely that your thermostat isn't functioning properly. change the settings and wait to see if it responds. If the thermostat is working it should shut down the compressor when you increase (rise) the temperature and aversly start it when you drop the temperature. Always let the unit sit for 3 minutes for the pressure inside to equalize before restarting. Good Luck
Nov 19, 2008 | Turbo Air 49 cu. ft. / 1388 liter...
Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM Logo
242 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
