Question about Bosch Measuring Tools & Sensors
Need manual for a Bosch glr225
Need a manual for a Bosch model GLR225 laser measure pointer
3 Related Answers
c1apton15
Mical Caterina
  • 3400 Answers
SOURCE: I need a manual for
Go to Sears website, search service manuals and you can download it there.
Posted on Mar 01, 2011
  • 102366 Answers
SOURCE: Need a manual for a Bosch GLR225
If you're in the US please contact 1-877-Bosch99 (267-2499).
Posted on Apr 14, 2012
Terry Jones
  • 22 Answers
SOURCE: Bosch GLR225 manual
Same predicament and I called Bosch at 1-877-267-2499 and they sent one in PDF format by email in hours.
Posted on May 16, 2012
Tip
Laserpointer 3000mw
3000mw this laser pointer green wavelength 532 nm, with a particularly strong green light (650 nm 405 nm for red and blue). Wavelength is the human eye. Operation 3000 MW Green laser with high capacity 18650 battery life even longer.
In addition, you can remove the extension rings, transported to a laser with a smaller 16340 battery, you can run on our site. Beam power, maximize the use of batteries or fully charged batteries.
This Green laser 3000mw especially overwhelming: where beams of concentrated attention, it has a button to make it clearer and more efficient, it also closes the input the security key-this is a significant force. Of contact does not interfere with the child or a person of control measures, the security system is an important criterion.
This Green laser pointer is a very powerful, beautiful laser 3000mw facilities, more akin to a laser pointer as a light! This is one of our most powerful Green laser pointer laser. Additional recommendations are ideal for astronomy use light, visible light, especially light during the night. Its beam from a few things when the brightness is reduced, and watch the sky. In the range of approximately 5 km.
on Jul 25, 2014 | Office Equipment & Supplies
What does mW stand for in laser pointer measurements?
m stands for mili like 1/1000 and W stands for watts which is the measurement of joule/second (joules per second). So 5mW means the laser's power is 5 miliwatts or it is putting out 0.005 joules of energy per second. The higher the number the more joules of energy are being emitted.
Sep 11, 2013 | Office Equipment & Supplies
Apr 14, 2012 | Bosch Lasers & Measuring Tools Bosch Wall...
Bosch GLR225 manual
Apr 08, 2012 | Measuring Tools & Sensors
The ads for this device state that it uses the Pythagorean theorem to figure the distance of a 3rd side, if you can measure the other 2 sides. I How do I use this feature?
1) There is a big difference between Bosch promo manual and Bosch operation manual:
2) Online promo manual says: Combined Indirect/Pythagoras for measuring total height from a distance
http://www.boschtools.com/AboutBoschTools/RequestProductLiterature/Documents/2010%20Catalog%20PDF/2010%20Measuring%20Tools.pdf
3) Online operation manual shows no instructions for Pythagoras measuring.
And shows no button for displaying E value or height.
http://www.engineersupply.com/images/bosch-tools/Bosch_Digital_Distance_Measurer_130k_User_Manual.pdf
4) Operation manual shows:
Length Measurement** and tells you to measure the height while promo says tool will calculate height E
Area Measurement*** shows rectangle only and not triangle
Volume Measurement
Area or Volume
Rounding of Large Calculations
Continuous Measurement (Tracking)
5) I would contact Bosch directly:
http://boschtools.com/Service/ContactUs/Pages/default.aspx
6) Until you get satisfaction from Bosch, the Bosch device gives precise menasurements that can be entered into a Pythagorean calculator online, which defeats the purpose of a jobsite tool: But you can access online calculator via cell phone while on jobsite.
http://www.analyzemath.com/Geometry_calculators/pythagorean.html
Feb 19, 2011 | Bosch DLR130K Laser Distance Measurer
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
Jun 17, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
Use of bosch dlr165 when there is no direct line of vision
northerntool.com has a few wheel meters that roll along the ground and will give you a fairly close measurement. or you can use the string method where you take a string and stretch it as close to a straight line as possible then mark it then get it out to where you can measure the string.
Dec 24, 2009 | Bosch DLR165K Laser Rangefinder Kit
Measuring Tools & Sensors Logo
164 people viewed this question
Top Bosch Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
