SOURCE: hp deskjet d2660 resume light blinking fast..
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
SOURCE: trying to install HP Deskjet D2660 - is it
yes it should be, try to plug it in and see what happends. the windows 7 should install drivers automatic.
or go here and download the windows7 driver for your printer.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=al-68601-2&lc=en&dlc=en&cc=us&lang=en&os=4062&product=3742936
good luck
Testimonial: "Thank you you be the man"
SOURCE: Hp Deskjet D2660 Printer driver
http://welcome.hp.com/country/us/en/support.html
you can download at link above
SOURCE: how to activate the selftest of my hp deskjet
Welcome to FixYa1
To print a self-test page,
1. Load the printer with white paper.
2. Press and hold the Power and Cancel button at the same time for about 3 to 5 seconds.
3. The self-test page will print.
It will look something like the picture below:
Thank you for using FixYa.
Keep me posted.
Jas247
