Question about Korg M50 61-Key Music Workstation Keyboard - M5061
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Posted by djohns on
Curtis Winger
    New Friend:
  • 23 Answers
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Posted on Apr 14, 2012
4 Related Answers
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: I recently bought a Korg
check the firewall in both places in control panel ..and on the antivirus if it has...and try to turn it off and see if it works ..cause if you have the correct driver and the software ..and it is seen already ..
check in device manager and see if ti is ok ..if it is in yellow it needs another driver cause it is not working ..look for the device by name ..
Posted on Jan 03, 2011
  • 11 Answers
SOURCE: Where can I get the Korg m50 service manual or
http://www.korg.com/SupportResults.aspx?productid=413 just click here :)
Posted on Feb 28, 2011
Fred Yearian
  • 5603 Answers
SOURCE: Hi Iam using my
The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
Posted on Jun 25, 2011
cosmin_bcr
Cosmin Becheru
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
Posted on Oct 06, 2011
Unlocking disc for sounds
Probably your best bet is to use a sound editor/library. Move the sounds onto your computer, then into the librarian editor, then from there through midi into your keyboard.
Sep 16, 2017 | Korg Music
Korg m50 gm sound not plying on my keyboard
try resetting it to its factory setting,
Sep 05, 2016 | Korg Music
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
My corg m50 board not orking gm not ork
Your best bet would be to contact Korg directly. Here is the link to their USA support page
Contact KORG
Feb 11, 2015 | Korg M50 61-Key Music Workstation Keyboard...
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Jun 08, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How to reset the korg m50
PLEASE HELP ME... this appeared in my KORG M50.. says. LOADING OS FAILED..... Is ther a solution to this...
Jan 23, 2012 | Korg M50 88 Note Workstation
Where can I get the Korg m50 service manual or parts manual?
Feb 26, 2011 | Korg M50 61-Key Music Workstation Keyboard...
Korg M50 61-Key Music Workstation Keyboard - M5061 Logo
951 people viewed this question
Top Korg Music Experts
Vernon Taylor
Robert Graf
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
