I do not know how to fix the print when printing a document it gets cut off on the left hand side of the paper. currently our computer tecks adjusted my margins on my computer but now the printing is to the right and it is very small
SOURCE: Left side of page cut off printing from Outlook 2003
Have you try to Copy paste the content of Outlook to Word and then try to print.
As Outlook have lesser option to set for printing. And may not possess all the features to print it correctly.
Let me know if I can assist you further.
Regards
Ellin
SOURCE: Big Black not printing
Sounds to me your print head is plugged up. This is not usual though because the majority of people use black ink much more. So, in your printer utility, do a deep cleaning. If that does not work, there is a thing called a purge unit in it. This is a usual way of draining waste ink to a pad that soaks it up. if the hose, or other parts are clogged, it backs the ink up and causes the print head to clog. If this is the start of it, do not waste your ink cleaning, and try not to let it sit too long. Contact canon, and let them kno what you think it is.
SOURCE: Printing
Do not continue this way, you are sure to ruin your paper sensor or the like. Most probably you have a paper jam inside near the carriage or roller. Open at front, check inside for paper jam.
SOURCE: Paper Feed
I had what sounds like the same problem. I had been using my printer earlier and then it started pulling the paper to one side (same side as yours). After trying the basic stuff ...I turned the printer upside down ...and out fell an almond. How it got in there I don't know..(I think my neighbours' little girl was eating them and must have dropped it in when she was visiting. ) I'm not sure if there was more to the problem than this ..and that seems almost too simple, but after the almond was out the printer started working just like before. I don't know if your problem might be similar but I hope maybe this can help.
