FCC ID:A3LSGHT105G IMEI:012794/00/806648/6 S/N:RPCB879440N
Samsung t105g codeunlock
Plesae i need unlock code for samsung sgh-t105g. am desperate for researching it code pls help me
this my email: [email protected]
Not it.................. help
SOURCE: i need the network unlock code for samsung SGH -E390
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next
a SIM card from a different service provider needs to be pushed half in
- (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
The phone is finally unlocked.
SOURCE: i would like unlock code so my samsung SGH-X530 accepts any sim please
1. remove your simcard
2. type *2767*3855# ALL DATA WILL BE LOST.
If the phone is locked with firmware then the code wont work.
let me know if it works.
SOURCE: how to unlock AT&T Samsung SGH-A137 my imei is 011662004175117
Go to Att.com and go to unlock sim card section. You will get the password there. DO NOT enter the password unless you have the correct code. If you entry the wrong code 10 times it will burn up your sim card.
SOURCE: samsung SGH-x475 t-mobile unlock code
sure the unlock code goes as follows... *2767*6903557610011172#
after you do that it will seem to shutoff but leave it and it will then open up to working screen... you will have to enter this code each time you turn off the phone but it should work,,, if u have any questions... e-mail me at [email protected]
If you are trying to use a SIM card in your phone and
getting a message like "Enter Subsidy Code", "Incorrect SIM
Card", "SIM not provisioned" or similar messages, then you need
an unlock code for your mobile phone. You can get Samsung SGH-T105G Unlock Code from the
network provider, they will provide you a code with easy to follow instructions on how to unlock your phone. I suggest to visit Samsung Unlock Code
site, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
How to pull a samsung T105G T moblie
