2003 Nissan Altima Logo
Posted on May 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've gutted all my catalytic converters and car still wont accelerate smoothly or go over 80 mph
The dealership told me it was a clogged Bank one cat and I had it gutted, my car doesn't allow me to go over 80 mph unless its cold/winter but everytime it warms up, my engine light comes on and car wont accelerate pass 80 mph, it gets up to 80 mph and the the injectors shut off and the speed needle has to go back to 60 mph before i can resume driving/accelerating, it does this faithfully, so now im goint to change my speed sensor and clean my mass air flow sensor, I've already gutted and cut off all my catalytic converters
Bill Boyd
Level 3:
Top Expert:
  • Nissan Master 53,816 Answers
  • Posted on May 05, 2017
Bill Boyd
Nissan Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11944459
Points
172802
Gutting the cat converters was not a smart thing to do
the ECM needs feed back from the sensors to regulate the air/fuel mixture and now you expect it to do the job with half the sensors removed
like trying to brush your teeth with no hands
replace the cat converters with new ones then run the fault codes to really find the problem area
1 Related Answer
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Jun 10, 2011
SOURCE: Hi..Im driving a Nissan Presea
I too be live first thing to check oxygen sensor, possibly fuel filter . Hope this helps some.
2answers
2008 gmc canyon will not accelerate over 80 mph
Fun a fuel flow test on the fuel system. You may have a restriction in the lines of filter. Also make sure that nothing is blocking the accelerator peddle from opening all the way. Use a scanner and check voltage the throttle body is getting from the sender.
I've had a trouble code( P0420) code come up,
Catalyst System Efficiency Below Threshold (Bank 1). OK, now tell me that again in plain English please.... let's break it down: the catalyst system being referred to is your three-way catalytic converter; so the catalytic converter is not working properly (i.e. it's not efficient). Bank 1 refers to the side of the engine which contains cylinder #1. On inline engines such as 4 & 5 cylinder engines, there is only one bank. So, to really simply things let's just say that the efficiency of the catalytic converter and/or exhaust pipe and/or O2 sensor is not so great. Hope this helps.
2006 ford focus won't accelerate
Check your catalytic converter under car...When it starts to clog up...Your car want accelerate correctly...Puts back pressure on your motorr
2003 Mitsubishi Diamante, power loss
If your car idles and runs smooth after everything you've done, I would almost say clogged catalytic converter just by the power loss.
Change catalytic converter on 2003 tiburon
If you have the V-6, there are actually 3 converters. One on each engine bank and one after the Y pipe
We've been recently told (after our check engine light came on, no longer any horsepower left to accelerate and once stopped can no longer start the vehicle) that our 2001 Hyundai Sante Fe had a...
If your mechanic is right about catalytic converter at fault then you can ask him to just remove those for a while and check if your car works fine. Catalytic converter are there just to reduce pollution and I don't recommend to drive without them but for checking you can do that for a while.
1helpful
Doesnt accelerate at 40 mph, loses power, jerks alot, and vaccum problem
check for a clogged catalytic converter in the exhaust system...that will cause the symtoms u r having...have a repair shop do a back pressure test on the exhaust system in front of the catalytic converter if is is more than 3psi u have a clogged converter
My 1985 celica gts bogs down when i accelerate... I changed the fuel filter that did not help it idles smooth and everything if i am driving slow it is ok only when i goto accelerate fast it bogs down wont...
It sounds like you catalytic converter is clogged. You can get a universal replacement cat from Jeg's for $50.
If it is a clogged cat, it will be getting really hot.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
