Question about Armitron Chronograph Sport #204345BKBK Watch for Men
The strap broke on my Armitron Pro Sport 49/1000 need replacement
The strap is not a standard one MD06117
Roger
    New Friend:
Try to search on amazon. here Amazon com Armitron Sport strap. I hope I have helped. Cheers
Posted on Dec 01, 2014
3 Related Answers
Aloke Das
  • 1833 Answers
SOURCE: Hello. Appreciate help in finding
Hi, According to your requirement, you have to purchase the strap. You can contact with nearest Armitron dealer or you can visit http://www.armitronservice.com for a replacement of strap. their mail id is [email protected] and contact number is (248) 767-8927. You can purchase the same strap from http://www.bizrate.com/watches or http://www.amazon.com. Just visit and choose your product and add it to cart. Purchase your product online by a valid credit card with postal information.
Posted on Aug 27, 2011
SOURCE: do you have directions for
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Posted on Apr 22, 2011
Andrea Searcy
SOURCE: how do you set time on the Armitron Women's Sport
Here is what I found....
Hi, I have a 40/6753 and here is what I found to set the watch
................Adj......................Start/Stop
...............Mode
.............................EL
Press and Hold down the MODE button until the display starts to flash that you are Adjusting the alarm. If you need to adjust the alarm here ya go :)
Press the mode button again and it switches from adjusting the ALARM to adjusting the TIME.
At this point the display will be flashing the seconds. Press the ADJ button and it will switch to Adjusting the Minutes. Press the AdJ button to advance the minutes.
Pressing the Start/Stop will switch to Adjusting the Hour. Again pressing the ADJ button will advance the Hour until you get to the correct one.
Once correct press the Start/Stop to switch to Adjusting the DATE. Press the ADJ to advance Month and Day.
Pressing the Start/Stop will finally switch to Adjusting the DAY OF THE WEEK. (little circle to the left hand side). Again, pressing the ADJ will advance the Day until correct.
This took me an hour just pressing buttons until I could figure this out. I hope this helps everyone.
Joe
Posted by: Joe From Oregon on February 04, 2008 at 09:39 PM
Posted on Nov 02, 2011
The watch is too small to go around my daughter's wrist. Are there more links available for this watch?
If it is astandard strap, probably site where they sell a watch migh have spare links. If it is a non-standard strap, it's not so easy. They might find out some compementary solution or might be more practical to buy a new strap.
Apr 30, 2015 | Watches
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
Have a longines watch circa 970 but need new links for the strap longines cannot help me ,so now what
If you haven't already tried it, I suggest replace the entire strap.
Most watches have standard sized lugs, so it should be possible find another one that you like and also fits your watch.
Dec 27, 2010 | Watches
Where can I buy a watch strap (double pin) for a Fossil FS3041?
mcdevito75 here, You can but a new strap for your Fissil watch almost any where, Ebay, or you can look for a small watch repair shop in your area as they would have the watch right there for a perfect fit. With anything else you"ll need to know the MM size of your strap. As the strap attaches to the watch case at the pins, simply measure in MM"s this is the size of the band you need, if you can only measure in Standard Measurement use the search online for conversion Inches to MM. But with a watch shop they do everything for you.
Sep 01, 2010 | Fossil FS3041 Wrist Watch
I'm trying to find out the measurment of the band of the watch because I want to replace it, and althoug I measured it myself, I find different measurments on the internet
Measure between the lugs, (where the currently installed bracelet/strap is installed. It should be measured in millimeters as that how all straps/bracelets are measured. Standard men's widths are 20, 22, 24 and some 26mm. There are of course, variations like proprietary bracelets and straps made to fit watches which will only accept the proprietary size made for it. These are usually much smaller (18, 14, 16mm) and integrated into the watch body design.
Jun 07, 2010 | Citizen Perpetual Calendar BL5260 50E...
Its broken and I need a replacement strap. I order one from Invicta three months ago and still haven't received it.
Have you tried your local watch shop?
Unless the strap has an unusual fitting, a standard type should do the job.
Mar 23, 2010 | Invicta Grand Lupah 2236 Wrist Watch
I have wave ceptor 2734 watch strap needed mine has broken. or will it be cheaper to get another watch with same model number
I have a similar watch and as far as I can see a standard watch strap can be fitted.
Go to your nearest watch shop and ask if they can fit one for you.
Feb 19, 2010 | Watches
Watch strap
I have looked at their web site and it is not in the least helpful!
Do you really need and Kenneth Cole strap? Most of the ones that I looked at seem to have standard strap fixings and any makers' strap can be fitted.
Your local watch shop might be able to supply something suitable.
Jan 16, 2010 | Watches
Can't set day of the week for armitron MD06117 mens watch
Purchased my Armitron men's digtal watch in 2009. Here's the twist on setting the name of the Day of the Week on my watch. When you get to the name of the Day of the Week flashing.. you don't get Su...Mo...Tu... You get 01..02..03... up through 99. (You think.. what the hell is this??) DON'T TRY TO SET Sun.. Mon.. etc here.. you won't find it. The puzzle solver..and it is.. IS TO SET THE LAST TWO DIGITS OF THE YEAR HERE.. Example... it is now 2010.. so scroll thru the numbers and set it to "10"!! Now.. when you go and set the numerical day date e.g. 3 for March, and set the numerical day - e.g. 15, the on-board computer?? in the watch will AUTOMATICALLY SET THE NAME OF THE WEEK!! It will look-up For Example.. in the year 2010.. 3-14 is SUN.. and will set it as that!! Hope this saves you some frustration. Regards... [email protected] (Mar 14, 2010)
Mar 06, 2009 | JCPenney Armitron Sport Link Bracelet...
New watch strap
I got mine from ebay. Its tough to install but I used a pen knife and a very small sdrewdriver. you can do it.
Good luck,
Techjoel
Feb 17, 2009 | Casio G-Shock G3110-1V Wrist Watch
Armitron Chronograph Sport #204345BKBK Watch for Men Logo
Top Armitron Watches Experts
Bruce Robin
ray gallant
ADMIN Canada
ADMIN Canada
Are you an Armitron Watch Expert? Answer questions, earn points and help others
