Question about Fisher and Paykel WA37T26G Top Load Washer
Fisher Paykel WA37T26G doesn't spin as fast as should in rince and spin cycle
Fisher Paykel model WA37T26G top load washer when it goes into the spin and rince cycle, the water sprays in and the washer stops for a moment, it then starts to rotate at a slow slow speed and then stops again, it starts to rotate again a lttle faster and makes a strange grinding noise and then starts to speed up. It never does reach the full rotational speed that it had in the past. I have tried to stop the machione and rebalance the load and also relevel the machine. No success.
Posted by Steve Bretl on
  • Steve Bretl Apr 12, 2012
    There are no flahing lights that might indicate a code. The machine continues to go through it's normal cycles as it seems, but doesn't get to full RPM.
Dr Jeffrey Morris
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 122 Answers
Check motor brushes, or binding brake, centrifugal clutch Re: Jeff
Posted on Apr 12, 2012
5 Related Answers
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: my fisher and paykel smartdrive
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Posted on Dec 15, 2008
Anonymous
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
luisa_sgro
  • 713 Answers
SOURCE: Fisher/Paykel WA37TG1 washer. goes through the
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Posted on Jul 20, 2010
luisa_sgro
  • 713 Answers
SOURCE: My fisher and paykel WG708 top load washer fills
Hi just read your posting.Could you confirm the model number for me,Is it GW708?Now the lights that stay on when the machine is beeping will be in a row of 8 lights.Starting from left to right which ones are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Posted on Aug 06, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My Fisher and Paykel GWL11
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Fisher-paykel washer fills on final spin cycle
Does your machine have a diverter valve,
If it does the valve is stuck in recirculate mode.
Lint has jammed it closed.
Feb 07, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't empty and spin
You either have a blocked water pump or more likely a blocked diverter valve. Easy to fix if you are handy. Tip machine back on a 45 degree angle and let rest against the wall. It is a matter of disconnecting a coupe of clamps and twisting the pump counter clockwise.
Dec 25, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Agitates but won't spin out
You have to get to the water pump and check to see if you have a clog in it first.
Sep 25, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Apr 20, 2010 | Fisher and Paykel WA37T26G Top Load Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel WA37T26G Top Load Washer Logo
415 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
