Question about OKI C Office Equipment & Supplies
Oki 5750 fatal error 231
5 Related Answers
Anonymous
SOURCE: Oki C5200n 002: Fatal Error
We have to change firewall settings in our Fios router. I just don't know which ports or udp to open.
Posted on Jan 08, 2008
Jeff Hughes
  • 97 Answers
SOURCE: fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Posted on Dec 08, 2008
Anonymous
  • 24 Answers
SOURCE: getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Posted on Jan 24, 2010
Anonymous
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Jeff Hughes
  • 97 Answers
SOURCE: fatal error 231 on oki c5800 after changing toner,
From the service manual, doesn't look good.
A technicain will have to look at the printer.
RFID Reader I/F Error
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Posted on Mar 29, 2010
Fatal error 231 error 3
RFID Reader I/F Error An interface error was detected
01: communication error between
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
chip.
04: the RFID Tag detection error
Jul 17, 2014 | OKI C6100n Laser Printer
How can I fix oki c3530 231: fatal error 03?
PCB.
the RFID reader.
chip.
Jun 21, 2014 | OKI C5800Ldn Led Printer
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Printer stopped
Error 231 could be caused by multiple issues. The RFID R/W PCB, CU/PU PCB just to name a couple. This might be best left to an authorized service agent.
Nov 09, 2013 | Oki Electric Industry C610dtn Laser...
OKI C5650 231 FATAL ERROR 03
I tried putting 1.5mm of plastic foam under the RFID chip to raise it up in the toner cartridge. This seemed to work.
Jan 17, 2012 | Office Equipment & Supplies
A message keeps flashing up 231 fatal error. Can you let me know what I need to do. 0116 240 3430 Dorothy
231 fatal error is telling you that the data from the chip on the toner cartridge is invalid or cannot be read.
This may happen for one of the following reasons:
1)The printer is unable to read the data on toner chip because of toner dust or dirt inside the printer.
Solution: Clean the printer inside, clean toner slot and drum.. See:Clean your laser printer.
2)Either the toner is not an original cartridge, it is refurbished or refilled, or the chip on the toner cartridge is defective.
Solution: replace the toner, or replace the Chip on toner cartridge.
3)The toner sensor in your OKI is defective.
Solution: Call the support number listed on the printer manual to arrange repair.
Jun 07, 2010 | OKI C5800Ldn Led Printer
Fatal error 231 on oki c5800 after changing toner, tried power off/on still doesn't work
check the device.
Mar 08, 2010 | OKI C5800Ldn Led Printer
231 Fatal Error 03 means what
chip... THATS THE CHIP IN THE TONER CARTRIDGE
Jan 10, 2010 | OKI C5500n Laser Printer
Fatal error message says ''231: fatal error 03''
It doesn't sound good, but a trick to try is to unplug the printer to see if that reset the board.
Nov 24, 2009 | OKI C5500n Printer
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
