Question about 3Com SuperStack Computers & Internet
3com superstack 3 switch 3300 reset himself randomaly need a solution
Power on the 3com switch and randomaly the 3com reset hiself, we have 5 units with the same problem. Please advis, Thanks, Pini.
Posted by Pini Haimovitz on
  • Pini Haimovitz Apr 12, 2012
    Please send me moer information about your solution.
    Thanks,
    Pini.
rech gred
    New Friend:
    Problem Solver:
  • 9 Answers
Take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Posted on Apr 12, 2012
1 Related Answer
bean_dip1
  • 17 Answers
SOURCE: I want to know the
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Posted on Jul 18, 2011
How reset 3com 4228g switch
If I remember correctly, there is a tiny hole at the back or on the side. Press a paper clip into it. The switch should do a full reset and then reboot. If its just locked up, I would switch off at the power for 15 mins and try let it do an auto restart itself. Do this before you go doing a full button press reset as you may lose any or all updates the switch has had loaded into it.
Sep 02, 2014 | 3Com Computers & Internet
3com Switch Intermittently Losing Connection.
this could be a problem with the second switch unit. what happens if you connect a pc to this cable, is that intermittent, if so, that is your problem. try fault finding with a LAN cable tester to see if there's any issue with the link cable.
Jul 16, 2013 | 3Com Baseline Switch 2024 24-Port...
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
I forgot my admin password on my 3com baseline switch 2226-sfp. i can't remember. Can you please help mo to reset my baseline switch to reset the password only. Thanks jenry
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
Feb 25, 2011 | 3Com 3C16475A Baseline Switch 2226...
Benji
sound like its fails the post.manual says should yellow if it fails, green if it passes. maybe hard reset unplug it from power wait a couple minutes plug back in.
May 21, 2017 | 3Com SuperStack 3 4226T (3C17300)...
The switches under 3Com 5500G- EI cannot communicate each other
I don't know anything about them, but here's a 444 page pdf on them. Hopefully it will help:
http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02583472-1.pdf
Feb 19, 2018 | 3Com 5500G-EI
Random crashes of 3Com NBX V3000...
Call 8008763266. Also check 3Com Primus Knowledgebase for savecore procedure.then check nboss.log.
3Com NBX Support Team
Feb 12, 2008 | 3Com NBX® V3000 (3C10600BUS)
Computers & Internet Logo
1,420 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Sheldon Dedek
Vincent G
Vincent G
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
