A
Anonymous Posted on Apr 12, 2012
Como instalar um receiver pioneer vsx 305 - Pioneer VSX-305 Receiver
5 Related Answers
Anonymous
  • Posted on Dec 29, 2008
SOURCE: MANUAL NEEDED FOR PIONEER VSX-305, FREE ?
i have the manual but am using it now. if i could get you a copy it would be fine
Anonymous
  • Posted on Sep 17, 2008
SOURCE: Pioneer Home Theater System VSX-305 owners manual
Dear Sir/Lady
I wat to get the
Pioneer Home Theater System VSX-305 owners manual Thanks a lot
WILLIAMS
Gustavo M.
  • 30 Answers
  • Posted on Aug 02, 2009
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Anonymous
  • Posted on Jan 28, 2010
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Anonymous
  • 2992 Answers
  • Posted on Mar 02, 2010
SOURCE: diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Pioneer Receiver Manuals
Go to eservice: http://www.eserviceinfo.com/index.php?what=search2 and search for VSX-305. You can downlaod the manual. The service manual is widely found with a google search but is also listed at the eservice website. Oh, Ebay has the service manuals as well.
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
How can I connect an HD LCD tv to an ancient (I think 1980s) Pioneer Receiver Model VSX-305? The receiver is in great condition, and I'd rather not replace it. I have Bose speakers connected to i
I have never seen RCA to digital conversion, and if it did exist you would have to convert from digital to analog in order for this to work, the sound quality would be degraded and unreliable, plus sound level would drop.
1helpful
2answers
Need a pioneer vsx 305 remote
Search eBay for "Pioneer vsx-305 remote" and check the 'Include description' box. Many available.
1helpful
No power
I had the same problem. I picked up 3 fuses to replace inside the Amp. and it has worked ever since.
Do you havea manual for this that you could send my way via email?
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
305-vsx
You need the remote...or a universal remote you can program to the VSX-305 to un-mute it.
4helpful
2answers
Dear Sir/Lady
I wat to get the
WILLIAMS
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
