SOURCE: ink absorber full warning
Yes, first unplug the power chord and then the usb chord. When you are done doing that, take the printer to an area where you have a little working space. Put it down on some newspaper. Open the lid. (Normally, when you open the lid with printer on, the cartridges will slide over to the left of the machine, this is important to remember for part of the cleaning). Now, with printer lid up in the air, look down inside the printer. you will see some plastic running horizontal with the printer ribbon, (the area I am referring to is right under where the ink cartriges slide back and forth)on the floor of the printer. If you take your finger and feel inside, you will find a very thin, narrow piece of foam in between the plastic strips. You can gently remove this foam and clean it with denatured alcohol and let it completely dry before replacing. You can also go in and clean the plastic area with a Qtip, because there will be a residue of ink all over this area. Also, right under where the ink cartridges park when opening the lid when plugged in is another small piece of rubber pad that should be cleaned too. Once you have done this, and this is important.. before, and during the replugging of the usb plug and the power chord, YOU MUST keep the "on key" pressed in. This is going to help reset your printer once it's plugged in. So keep your on button pressed down and plug both chords in. ONCE that's done, let go of the power button. It will go on and run through some of it's noise. The yellow light might come on again, that's okay, just turn off your printer, wait a few seconds and turn it back on. It should work fine. We did this because we had read about holding in the button for resetting. If you clean the ink pads in the future you must do that because it actually is resetting something in your printer. Mine works just fine. I will add that I went through a lot of ink cartridges to get to this point but it is pretty easy to clean if you just take your time, be patient and carefully remove the foam not to damage it. Good luck
SOURCE: Canon pixma ip3000
This should do the trick!
i320 waste ink counter reset.
1. Turn off the printer.
2. Press and hold the POWER button, turn on the printer.
3. The indicator should be green.
3. Press and release the RESUME button , the indicator should be orange.
4. Press and release the RESUME button again, the indicator should be green.
5. Release both buttons.
6.Connect the printer to PC.
7.Open General Tool software,choose ¡°USB PORT¡±.
8.Choose ¡°SET DESTINATION 1 ¡±,OK!
You can download the software at: http://www.it0577.com/yezmao/i320.exe
SOURCE: ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
SOURCE: indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste
ink from cleaning the print head. Over time, this pad fills up with ink
and can no longer hold any more. When this occurs, the printer
indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing
the waste ink absorption pads is something an authorized canon service
facility can take care of for you. Once they are replaced,
it'll be functional again.
SOURCE: Waste ink absorber is almost full
if this happens, just turn off the printer plug,then hold the
reset\stop button,after that you turn on the plug while pressing the
stop reset button, then follow these steps
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
(optional)
To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
