Sound not working
Before you assume the set has a audio problem here are some other possible causes to at least explore:
Speakers in the set (menu) are switched off.
Volume and set and or box turned way down or muted.
Internal/external speaker setting set to external
Audio works with a DVD etc connected to rear a/v jacks
Set suffered a power outage=unplug set and boxes and wait--plug both back and see if fixed or not.
Set does display on screen audio level or not--same for a box if used.
Check all audio settings in set and box carefully
If all these fail do you hear a hum or very faint audio from the speakers?
SOURCE: Hitachi L42VC04U cant get freeview
The easiest way to check if the fault is with the TV or the aerial is to plug the TV in where the other WORKING TV is connected to the aerial.
If it works, then you have a problem with the aerial or the aerial cable.
If not check that the TV isn't in analogue mode. Press the "DTV" button on the remote. The TV should display "DTV" in the top corner of the screen.
If you are definitely in digital mode, and freeview doesn't work when the TV is connected to the other aerial connection, then you probably have a faulty TV.
Is the TV new or was it working OK previously?
Please rate my solution if you find this helpful. Thanks.
