Question about HP PhotoSmart C4385 All-in-One Printer
Hp c7250 blurry printing - HP PhotoSmart C4385 All-in-One Printer
1 Related Answer
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Posted on Aug 23, 2009
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
My hp c7250 printer will not recognize paper in main tray and gives me an out of paper error message. How do I get the printer to recognize paper?
My C7250 just did the same thing a couple of minutes ago. It works now but I'm not sure what did the trick. I put in a single sheet and pushed it with my finger. After a couple of tries doing this, it grabbed the paper and printed.
So far it has printed 5 sheets without a problem.
Nov 27, 2010 | HP Office Equipment & Supplies
My HP C7250 inserts a blank page between every printed page. Windows Vista PC.
Perhaps this is a characteristic of the document being printed: Manual paper feeds in addition to the automatic paper feed characters? Use the word processing program matching the document to remove the unwanted paper feeds.
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
Last line or two of print gets cut off
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Jul 29, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 PRINT JOB REMAINS IN QUEQ THEREFORE WONT PRING
I responded to this on another page turn off printer at power. Turn off or reboot PC then the ques is emptied. Follow my other suggestion for using the right driver and setting up the prnter again in Vista
Jul 28, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Aug 02, 2008 | HP Photosmart C7280 Laser Printer
HP PhotoSmart C4385 All-in-One Printer Logo
47 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
