I'm not sure of your question. An iron has a small funnel shaped hole. That is where the water goes. Some irons have a sight glass that tells you how much water is in the iron. Use ditilled water in an iron to prevent build-up of mineral deposits which can clog the iron.
dump what water is still in iron. refill with white vineger turn turn on after a day soaking with iron hot use on old towel. dump remainer out. hint when filling iron with water only put small amount so water isn't laying inside when not in use.
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust.
It is a pretty common problem that can be minimized by using distilled water.
You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar:
1) with a cold iron, fill the reservoir with straight vinegar
2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity.
3) Refill iron reservoir with clean water and repeat as of step 2.
4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
No need to open iron! You just unplug the iron. Hold the iron upright. Using a clean cup, pour water into the "open" WATER FILL HOLES just above or in front of the Temp. Select Dial. Watch the water window on the left. When water level reaches MAX, you are filled. Plug in and use. Refill as needed. Ref. - Page 8 in the instruction pamphlet.
Are you using distilled water to refill your iron? Distilled water can cause drips if used all the time. Refill with tap water and see if the drips stop.
