Question about Music
Need schematic for Crate PCM-8 DP+
Looks like one side of power amp is out.
Posted by Bob Farlow on
John McPherson
    Genius:
  • 1,212 Answers
Without a schematic you can still trace the circuit to locate the fault.
Put a music source or sound source into the bad channel and a good channel, and with an oscilloscope or with a pair of high impedance headphones with test leads on the ends- you can set up a low z headphone with an impedance match trasformer, make sure you have test prod ends on one of the leads. The other can go to a chassis ground. Start at the input and work your way forward comparing the signal between the good channel and the faulty channel. When you lose the signal or you encounter severe distortion, you are in the vicinity of the defective part.
Common failures are a Deffective 4558 or TL072/TL071/TL074 IC chip. You may have a faulty electrolytic capacitor, or even a faulty bypass caoacitor in general. Bad solder connections, even a broken fim resistor.
With the IC chips, the usual power pins for an 8 pin plastic or ceamic DIP are pins 4 and 8. usual outputs for the 8 pin are 1 and 7 the remaining pins are the inverting and noninverting inputs. 2 and 3 and 5 and 6.
Also check switches and especially those with interupts on the input and output jacks- they can get dirty.
Posted on Apr 11, 2012
  • Bob Farlow
    Bob Farlow Apr 11, 2012
    Thanks to all. I finally obtained schematic and found a faulty LM35 temperature monitor IC which was saying the heatsink was hot when it was really cool.
  • texanabs
    texanabs Oct 13, 2012
    Where did you obtain the Schematic?
2 Related Answers
Anonymous
  • 192 Answers
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
Anonymous
  • 1469 Answers
SOURCE: Crate GTX-30 Guitar Amp Schematic... The thing
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
Posted on May 31, 2010
I NEED THE SPECS FOR THE CRATE GT-200 AMP MAIN TRANSFORMER
Contact the Crate Service Department at 1-800-738-7563 or 314-569-0141 (8:30am-5:00pm central time, Monday-Friday) to order any parts and/or schematics.
Aug 05, 2018 | Crate Music
Need amp schematic for a Crate model vc6112
Web page with schematics and requests:
http://music-electronics-forum.com/t26486/
http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdf
http://music-electronics-forum.com/t16609/
http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdf
http://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdf
http://music-electronics-forum.com/sitemap/f-60.html
User guide at link below from 1998 has mailing address in St. Louis.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U
Crate VC 6112 Owner Manual
Feb 21, 2018 | Crate Music
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
or
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate PA-8 that hasn't been used in a long time. I destress and sing. Anyoo it has a power issue. Light is flashing on then goes off. I can't find a manual. Can anyone assist me please?
you have either a failing fuse or a failing power transformer. take out the screws on the top of the amp, leave the handle in tact and pull out the chasis. look at your fuse to see if it is in its holder correctly, and see if the fuse is burnt. the correct fuse values will be printed on the circuit board. if the fuse looks good then, it may be the power tranny going south.
May 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, [email protected]
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
862 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
