Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
How can i activate pre-installed webcam in my dell inspiron mini 1012
Posted by jemini_kumar on
Gaurav Kumar
  • Dell Expert
  • 560 Answers
Step 1: First connect the bluetooth device to USB port on your computer and check that it is detecting on your computer or not.
Step 2: Now insert the bluetooth software driver CD to your system that will auto start after few seconds then follow instruction to finish bluetooth software installation.
Step 3: Now go to 'start -> Devices and Printers' and click 'Add a device' from top of the window.
Step 4: Now your Windows 7 system will search the bluetooth device which connected to your system.
Step 5: Click the bluetooth device you want to install from the list and then click the 'Next' button and wait for windows to configure the bluetooth device. If prompted to enter a passcode, enter the default code listed in the bluetooth device manual. In many cases, the default passcode will be '0000'.
Now the bluetooth device has successfully installed and ready to use.
Note: If you bluetooth device was not listed in the search results from Step 4, make the device discoverable. Access your Bluetooth-enabled device's settings page, and turn on the device's 'Listen' or 'Discoverable' function to allow you computer to find it.
Feel free to get Dell technical assistance anytime at http://www.vtechsquad.com/dell-support/
Posted on Sep 04, 2012
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: how do I restore factory settings on my dell
  1. Restoring a Dell System Running Windows XP.
    Turn off and reboot your computer. When you see the Windows flash screen, depress "CTRL" and "F11". Be sure to press them simultaneously and release them simultaneously.
    Select "Restore" in the "Dell PC to restore by Symantec" window and press "Enter".
    Highlight and select "Confirm" when the message shows that you wiill lose all data if you continue. This will begin the restore process. It usually takes about 10 minutes or so. When it's done, you should receive a message that states the system recovery process was successful.
    Select "Finish" to complete the process and restart your system.
  2. Step 6 Restore a Dell System Running Windows Vista
    Shutdown and restart your computer. Keep pressing "F8" until you see the "Advanced Boot Options" menu. You must depress the keys before the Windows Logo screen appears. If you wait until after the screen appears and then press "F8", it's too late and you'll have to reboot the system and try again.
    Navigate to the "Repair your computer" option
    Select the appropriate language and click "Next".
    Sign onto the system as an administrator. Without administrative privileges, you will be unable to perform the system restore.
    Select "Dell Factory Image Restore" and click "Next".
    Place a check in the check box next to the text that says "Yes, reformat hard drive and restore System Software to factory condition" and click "Next".
    Click "Finish" to complete the process. This will reboot your computer.
Posted on May 19, 2010
jimmy_k8
Jignesh Khare
  • 242 Answers
SOURCE: webcam of inspiron mini 1012 is not working. is it
Yes, it is only because of drivers. Install drivers but make sure that you install it for the correct OS that you are using.
Posted on Jun 04, 2010
Dre Williams
  • 92 Answers
SOURCE: web cam driver for dell inspiron mini 1012 windows
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1012&os=W732&osl=EN
When this works 4 u vote me a 10
Posted on Jun 16, 2010
sim4182
Shahzad Iqbal
  • 393 Answers
SOURCE: i have the Dell Inspiron 1012 mini, and forgot my
enter 3 time wrong code u will see a 5 digit code send me that one ill send u master password
Posted on Oct 14, 2010
Jazzy Tariq
  • 65 Answers
SOURCE: I have a Dell Inspiron Mini Laptop 1012, how do
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Posted on Jan 05, 2011
I needwebcam drivers
You may use the below link to find the webcam drivers for Dell Inspiron Mini 1012 with windows 7 operating system:
http://ftp.us.dell.com/monitors/Dell_SX2210-Monitor_Webcam%20SW%20RC1.1_%20R230103.exe
However, if this is not the one you are looking for/ if you have a different operating system then please let me know.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 09, 2014 | Dell Inspiron Mini 1012 Netbook...
How can I make my webcam work on my Dell Inspiron mini 1012 model after its operating system has been changed from Windows 7 starter to windows 7 Ultimate
To solve this problem you should download software driver from Dell website www.dell.com and installa them into your system
Aug 28, 2011 | Dell Inspiron Mini 1012 Netbook...
I have a dell inspiron mini 1012 and I have a problem about my webcam I need to a driver for inspiron mini webcam 1.3. I didn't find that help please
Hi mrv mrv uygu...
I can only direct you to the webpage where you can start to download the driver/s you need.
I do not have your service tag number, or other info that will be needed to get your driver for you.
Please take time to rate me
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Aug 04, 2011 | Dell Inspiron Mini 1012 Netbook...
I am trying to find the correct driver for a Dell Mini 1012 webcam. THe hard drive crashed and had to be replaced, and no access to cdrom to reinstall recovery disk. The system has a clean install of...
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R160323&SystemID=XPS_M1330&servicetag=&os=WW1&osl=en&deviceid=15135&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=214676
Jul 01, 2011 | Dell Inspiron Mini 1012 Netbook...
I have a dell inspiron mini 10 and the built in webcam doesnt work. I have tried skype video calling and the dell webcam central neither of which picked it up. How can I get it to work?
* go to cotrol panel and check the settings of your webcam
* might your webcam driver crash or corrupt.
* try to re-install the webcam driver included in your laptop package...
Jun 05, 2011 | Dell Inspiron Mini 1012 Netbook...
I don't have the driver for the webcam of the inspiron 1012, please help!
Please Visit the following website and choose the operating system and you can find the driver for you webcam. download it and install it.
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&SystemID=inspiron1012
Mar 27, 2011 | Dell Inspiron Mini 1012 Netbook...
My webcam on my dell inspiron mini netbook isnt working and cant be found in device manager
1st try holding down FN and F5 (or F button with camera on) If nothing works you can go to the dell website and install the relevant driver for your webcam. Hope this helps, if you need any further help or assistance i'll be happy to help
Mar 07, 2011 | Dell Inspiron Mini 1012 Netbook...
Webcam of inspiron mini 1012 is not working. is it the driver?
Jun 04, 2010 | Dell Inspiron Mini 1012 Netbook PC
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
155 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
