Vacuums Logo
Patti Van Posted on Apr 10, 2012
Bissell vacuum model # 4104 Powergroom has loud screeching noise when turned on
  • 1 more comment
  • Patti Van Apr 11, 2012
    Put new belt on, some loud screeching noise when turned on.
  • Patti Van Apr 12, 2012
    I did go buy a new belt and installed it but it didn't fix the problem at all.
  • Anonymous Mar 31, 2014
    it stops working
After replacing belt it started making too much noise when you turn on. What could be the reason?
You missed something then.. look further back in the vacuum stream or belt drive area for debris or foreign objects.
Vacuum is loud
Check for clogs starting with the air passageway at the bottom....
a piece of TV cable is great for clearing clogs there....check all
hoses...check for dirty filters. If you find no clogs remove the
brush bar and belt and start the vacuum...if the vacuum is no
longer noisy the problem is the bearings at each end of the brush
bar..... WD 40 may fix or you will have to replace. If after all this
the noise persists the the problem is in the motor. (If you use WD 40
make sure it is dry before you vacuum carpet)
Regards,
Dennis
Bissell PowerGroom Helix Rewind Vacuum 98N4 manuals
Hello, this is Ava with Think Crucial.
You may view the online manual for your Bissell model by clicking the link below.
Bissell 98N4 SERIES User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
1helpful
2answers
I need to know what belt is used on the bissel powergroom
The Style 2 Belt fits Bissell Powergroom Models 35301, 35351 & 35352.
I hope this helps.
Oct 19, 2012 • Vacuums
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Free instructon manual for bissell 4104
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell 4104 Series User Manual
Ava B.
1helpful
Very loud screeching ,continuous when turned on
Hi dfabin,
Does the screeching come from the motor area or the brush/belt area?
If it's from the motor. Turn it off. It needs repair.
If it's from the brush/belt area, most likely your belt is either slipping or rubbing on something.
Do you have an owner's manual?
If you do, and the noise come from the belts, take the belt(s) off and check them for wear, stretching, anything imbedded in them. Be sure to clean all debris out of the area. and reassemble. If still noisy, the belt may be slipping and needs to be replaced.
Here's a site where you can view the parts breakdown and order parts: http://www.vacpartswarehouse.com/Bissell-Healthy-Home-Models-5770-5990-6100-6405-s/600.htm
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
My brush roller isn't spinning on my bissell powergroom vacuum
You belt has probably broken or it has stretched to the point where it won't turn the brush against the resistance of the carpet. You need to change the belt. Below are the two possible belts you could need. Check and see if yours is a PowerGroom Pet (it will say on the vacuum) or just the regular PowerGroom model. Here are the belts:
Regular PowerGroom Replacement Belts
PowerGroom Pet Replacement Belts
Oct 30, 2009 • Vacuums
We have a Bissell Clearview Revolution #3595 and the motor when turned on Screeches, loudly, it does ****, just incredibly noisy we have already changed the belt
Sounds like a bad motor, part # 2032211It would cost around $60 for a new one. Did you check the brush roll to see if it is making alot of noise, if it is then replace it.
Nov 29, 2008 • Vacuums
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
