Question about Pentair Mastertemp Heater
R=8 128 Code on Pentair Mastertemp Heater what does it mean?
Heater comes on but stops heating after about 3 minutes then service heater light comes on. Heater stops heating for a few minutes then comes back on then after 3 minutes or so it stops heating again. Have turned it off rather than let it turn on and off contunally.
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
Dale Cobb
  • 366 Answers
SOURCE: I have a Pentair MasterTemp Heater 250K BTU (i
try cycling the power to the heater itself. Check for damage (pack rats, etc..). It sounds like you may have had a direct short. It could be a board problem or a transformer problem. If you're still getting the service heater light, check to see if any diagnostic LED is illuminated behind the board.
Posted on Jan 19, 2010
Kieran Ruppert
  • 990 Answers
SOURCE: I have a Pentair Mastertemp 250 pool heater with
This is an ignition flame falure code. Could be you don't have gas getting to the pilot, no spark to ignite the pilot or your ignition is not reading the flame. Sorry to say but it's probally time to get the pool guy out to look at it. Good luck.
Posted on Apr 15, 2010
Kieran Ruppert
  • 990 Answers
SOURCE: heater cycles on / off
This could be a water flo problem. you need to chech to be sure your by-pass valve is closed down enough to force water threw heater, There is a internal by-pass that could be a problem also, or a bad pressure switch. If the by-pass isn't the problem then you should check these also.
Posted on Jul 26, 2010
Anonymous
SOURCE: getting a E05 code on my Mastertemp pentair
I have same problem. Mechanic not sure what to do. May need a new board.
Posted on Jul 31, 2010
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
2002 ford escape periodically over heating
Check the thermostat and the fan too. Overheating nothing to do with the heater core, even if you shut the heat off, the car should not overheat
Mar 20, 2013 | 2002 Ford Escape
Model 21 ,start monitor and the fan starts and orange lights come on ,then the lights bounce to 100 % and then back to half and then back to 100% real quick and the fan qiuts and heater never gets the...
This sounds like it is going to be a circuit board issue. When you turn it on the blower should start and the igniter will begin preheating the burner. After 3 minutes the burn lights should come on and you should begin to see some flame with a few seconds. The heater should burn on low for about 10 minutes to allow it to become evenly heated before going to high.
Dec 10, 2010 | Heating & Cooling
Heater turns on and heats 2-3 degress then the service heater light comes on.After about 1 minute the heater fires back up and the light goes out and it repeats this cycle until it up to set temp.
Your "bypass valve" may be wide open, which causes the heater to overheat and shut down till it cools off. Just after the filter there is a pipe, then a valve, then another pipe.Close the valve at least 1/2 way (if not more). This will force water through the heater and keep it from overheating.
Oct 28, 2010 | Sta Rite Pool & Spa
My pool heater turns on, runs a few minutes, the igniter lights and the heater heats for about 3 minutes, then turns off. I see a SERVICE comment blinking and SW2 is also blinking.
im not sure what filter you have on there but do a good cleaning if its D.E acid wash it if sand clean the sand. your not keeping enuff pressure to keep it lite. take it slo
Oct 15, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Rheem 21V40S-2 does not heat water
all brands and models have a flow switch which protects the heat exchanger from overheating, a very common problem is calcium build up in the heat exchanger which reduces flow and causes the flow switch to shut off the burner. Can be fixed by descaling the heat exchanger. We have a kit available at heaterup.com its safe and easy to use.
Jul 03, 2009 | Bosch & Tankless LP Hot Water Heater
Pentair Mastertemp Heater Logo
2,818 people viewed this question
Top Pentair Pool & Spa Experts
Marvin
Marvin
David Spradling
David Spradling
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
