SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The
other way before Vista starts up is to tap ALT + F10 (at the same time
repeatedly) when the computer is first switched on.. The window of
opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then
it indicates that you have tapped the ALT + F10 correctly, and all you
now need to do is press “Enter” and the Recovery program should load on
your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
SOURCE: restore back to factory settings
From Acer direct
The
If you see this:
Then
SOURCE: Reset Acer Aspire One to factory settings--clean hard drive
You will have to order the erecovery cds from Acer to put it back to factory settings. They can about $40.00 to $50.00 dollars and they arrive about a week after you order them. Once you get them, you boot from cdrom and follow the instructions on the screen.
Go to Acer.com to order them.
SOURCE: restore factory settings of my acer aspire one? altF10 not workin
To start on safe mode try F8 few times and make sure that you do it before the logo comes up, it will take you to the selections that you need...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
