before doing this procedure,make sure that your phone battery is fully charge to avoid interruption and system failure.
1. turn off the phone
2. simultaneously press red key, blue key,camera button and power button.
3.when the phone starts to open,you can now release the power button but not the 3 buttons mention.
4. as nokia logo shown,just let it finish until the phone appear to choose your designated country,then you may release the remaining button as well...
If this method doesn't effect or changes does not made,just simply repeated the procedure until you got it right.
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
For Hard Reset: This also restore your Nokia when it frezzes at the nokia screen logo only and didn't go any further. hard reset is an options but will result to loosing all settings, contacts, data etc...
Turn your phone off and simultaneously press these four buttons circled in red.
* * (asterisk key) * 3 (numeric 3 key) * CALL / GREEN key * On button
This is another method below found out by trial and error when the * + 3 + Call didnt work.
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation.
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your phone.
4. Press and hold these three keys together
-Green dial key, -Star key (*) -Three key (3) then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
Disclaimer : I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
