Question about Life Fitness Exercise & Fitness
How can i loose mx weight and my tummy (tummy is more important)
Posted by nareshsirswa on
Nabeel Khan
  • 13 Answers
Very good tip to eat at least 3 hours before you sleep.
Other than that add gym to your daily routine and avoid junk and sweets (including drinks).
You can find some weight loss tips to lose 1 kg per day here: How to lose 1 kg in 1 day , however that's not recommended for all, just use the tips with healthy routine and you will rock!
Posted on Jun 15, 2015
ray gallant
    Top Expert:
  • 68,282 Answers
Do not eat at least 3 hours before going to bed .
Posted on Apr 16, 2015
johnny rebel
    Top Expert:
  • 10,875 Answers
Dan Shibata
  • 542 Answers
Eat right and exercise
Posted on Apr 10, 2012
I'm on trepilene 20mg. I gained a lot of weight mostly over my tummy. I do not sleep at all. Started since using these tablets.
fixya site is not a medical forum
side effects should be immediately reported to the treating doctor
May 02, 2018 | Health & Beauty
I have red sores on my tummy and i take an oil of primrose capsule every day is this a side effect
Internal bleeding! Stop using it.
see side effects tab here...
http://www.webmd.com/vitamins-supplements/ingredientmono-1006-evening%20primrose%20oil.aspx?activeingredientid=1006&activeingredientname=evening%20primrose%20oil
May 24, 2014 | Health & Beauty
Tummy tuck
Nhs is ok. Recovery is 4 weeks with no heavy lifting. Well worth it if u use a well known company not sure about Nhs. But to get it on Nhs just say u suffer depression and it should work. I had my tummy tuck 2 years back from Dr.mclean's clinic, Toronto. You cannot imagine how good it feels when it is done and the pain is gone. You look like you work out all the time, I had a new belly button and finally a stomach that I did not have to tuck into my jeans.
Feb 06, 2014 | Rodial Tummy Tuck Sticks x14
I have a 5month old puppy and her tummy is very runny
Loose stool in dogs is a super common problem. There is a short answer and a very, very long answer. The short answer is to try a bit of canned pumpkin in the food when you are noticing the problem. Use one tablespoon full in a small dog and two in a large dog in each meal. That is probably the best, most reliable remedy that is natural. Sometimes just feeding cottage cheese and rice or chicken and rice for a day or two will do the trick too. If those things do not help and the soft stool is continuing, it is probably best to seek the care of a vet.
Nov 12, 2013 | Hello Kitty & Puppy 4 Piece Baby Crib...
How i can loose tummy
Hello Dear
If you really want to loose your tummy, do the following easy exersise (if You are not asthamic) any one
1. Climb Stairs 10 to 15 times a day. Start with 5 times then increase it by 2 times daily that is
1st Day= 5 times
2nd day= 7 times
3rd Day= 9 times ..... and so on. till day 10. Increase it to 20 times a day and then stop increasing vut continueing your exercise. In 35 days You will feel the difference in your tummy.
2. Cycling: Lay down straight on your back with your hands under your head. And in air use your legs like you are cycling in air... Start this with 5 mins daily and proceed it to 20 mins daily.
It will take you a month and you will feel your tummy loose as faster as any other procedure or machine using exercise.
Note: Exercise 2 is proved by 10 other peoples. It is Granteed.
If you like my Solution please rate it.
best wishes
Mar 03, 2011 | Healthometer Health o meter Body Fat...
How much does the Maxent MX-50X5 Tv Weigh? I need to put it on the wall but everyone asks how much it weighs so i can get the right mount.
Weight:106.5 lbs according to plasma.com. i did simple websearch (boolian, example Maxent MX-50X5 Television+ weight) and the search came up with that. you may need to convert it to metric if your from outside usa. i would go with a bracket with a higher gross weight, and be sure to mount it where there are wall studs, the bracket will come out if not properly mounted and down will come your tv..
Best of luck
Oct 17, 2010 | Maxent MX-50X5 Television
Exercise & Fitness Logo
649 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
