My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
Posted by jakesacapani on
  • santiago_cos
    santiago_cos Apr 12, 2012
    It won't boot and no POST screen on start up just samsung logo then the monitor turn OFF then ON again just showing samsung logo but the power indicator still lights ON...plz help me
General Systems Consulting
    Top Expert:
  • 5,051 Answers
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Posted on Apr 10, 2012
  • santiago_cos
    No,just showing samsung logo then turn off,but power ligths indicators on and i can go to POST screen
1 Related Answer
SOURCE: My Samsung laptop rv511 won't
Check in the back side you can see battery inside the laptop. Pull it then reconnect .if still same then make sure your battery is working fine. There should be issue with battery if battery is fine then you need to take it to nearest service center because there is problem inside the laptop like motherboard or circuit related issue. most of time laptop battery create this type of issue..So check the battery. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jun 30, 2011
Samsung monitor brightness indicator stuck in middle of screen and won't disappear
its an option pyshically on your monitor there has to be some butttons near the power button of the monitor. play around with those and you might figure it out or
http://www.eanswer.com/tv-repair/?r=ppc'ga'9'HI%20-%20Electronics'TV%20Samsung&JCLT=Samsung&JPKW=samsung%20screen&JPDC=S&JPST=&JPAD=5822362509&JPAF=txt&JPCD=20100518&JPRC=1&gclid=CPqM5LPxlLUCFYVFMgodOiUA5w
if this helps please take time to rate
Feb 01, 2013 | Computers & Internet
My Samsung RV511 Laptop isn't getting power.
Most likely problem in this instance is a loose dc socket. it is a cheap fix or you can re-solder it yourself, if you have the ability.
Nov 26, 2012 | Samsung Rv511-a01 Laptop
Laptop RV511 shutdown during surfing
have look at your system indicator??
if CPU are full a too long time it overheat and the computer shotdown
try to see less page at the same time and close useless programmes
Oct 28, 2012 | Samsung Rv511
Touchpad screen scroll not working
You'll probably have to go to Samsung's website and download the proper drivers for it.
http://www.samsung.com/us/support/owners/product/NP-RV511-A01US
Oct 18, 2012 | Samsung Rv511-a01 Laptop
Trying to plug my Samsung RV511 laptop into my Apex TV via
Make sure the TV is set to VGA and not HDMI input or something else. Should be straight forward.
Aug 30, 2012 | Samsung Rv511-a01 Intel Core I3-380m...
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
Dell inspiron 1501 won't boot but caps lock flashes continuosly. when i remove memory it doesn't beep
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
Jun 30, 2011 | Dell Inspiron 1501 Notebook
Laptop fell to floor, cracking the screen. Was able to use content of computor via a separate monitor from another computor system we already had. Bought another monitor off of e-bay (Samsung).Monitor...
hi,
i think : no it is not safe for connection because each one of laptop use of the different graphic
and the fujitsu laptop for protection advise you at the booting up " auto adjustment is locked"
in the other hand each minitor use of the special voltage. therefore this flash advice at the
first of booting and before transfer the graphic data and power voltage to samsung laptop
alarm you : stop
i suggest you to contact seller
good luck
gorbesia
Jun 13, 2011 | Computers & Internet
My old Sharp Actius UM32W laptop powers off after about 3 minutes and the number pad "N" indicator light flashes. How do I fix this?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 19, 2010 | Sharp Actius UM32W Notebook
Computers & Internet Logo
642 people viewed this question
Ekse
Marvin
Marvin
