Question about Kodak EasyShare CX7530 Digital Camera
Camera's batteries seem always to go dead fast. then come back
For the past year, I've bought new battery chargers and new recharagable batteries, Have used Alchiline batteries. Have recharged other recharagables, The camera, has batteries with a good charge for a few pictures, then when turned on, goes from green to red flashing immediately. Sometimes I take and reverse the batteries and get going again for a picture or two. Then the same thing happens. Soetimes I lick the battery tips, hoping maybe to get some charge. Sometimes it works, sometimes it doesn't. sometimes I just open the battery case a couple of times and then close it and it works for a few pictures. I'm frustrated with this, once terriffic, but now difficult camera. Any help?
Posted by pitcher_robe on
5 Related Answers
Anonymous
  • 215 Answers
SOURCE: New Rechargable Batteries Die after A Couple of Pictures
This model is renowned for poor battery life. Some people say using the CRV3 battery lasts a lot longer but my advice is to buy NimH batteries with at least 2600mah. Some Nimh are only 700mah and obviously will last less than a third the time of a 2600. Keeping the use of the LCD to a minimum will increase battery life and using the flash puts a tremendous drain on the batteries so if you can do without the flash switch it off. Combine these tips with a set of 2600mah batteries and I'll guarantee you'll be pleasantly surprised. As a sideline I always have a good laugh when I see an Olympics opening at night or a firework display and all you can see is thousands of flashes going off which the majority only reach about 12 feet maximum and the parade being shot is some 300 feet away. BMW
Posted on May 30, 2006
Anonymous
SOURCE: Rechargable Battery Problem on Kodak DX 4530
Inside the battery compartment, on the same side as the battery cover hinge, you will see a small white mechanism. As I understand it, this is a microswitch which recognises when rechargeable batterys are installed. I suspect this may have been damaged. If so, you will need a rock-steady hand and brilliant eyesight to repair it. Even dismantling the camera is a challenge.
docramage
Posted on Nov 17, 2007
Anonymous
  • 58 Answers
SOURCE: EasyShare Z712IS
the camera will work with any brand of lithium but only the KLIC 8000 battery will work as a rechargeable
please look at your getting started guide and check page 1, there's an illustration of the 3 types of batts that will work:
lithium crv3, lithium aa and klic 8000
ni-mh is really not compatible
please check at the bottom of your camera, the three types of batts I mentioned are engraved at the battery door
thank you
Posted on Feb 13, 2008
Anonymous
SOURCE: GREEN LIGHT TURNS TO RED & CAMERA WON'T WORK
send it back and purchase a different camera
Posted on Jun 29, 2008
Anonymous
SOURCE: M753easy Share
Just let it recharge after the charge light went out
Posted on Jul 07, 2008
I have a Sanyo Xacti VPC-E60 EX Digital Camera.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 16, 2012 | Sanyo Xacti VPC-E60 EX Digital Camera
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
It will not charge up.
Recharageable should not be stored in a discharged state.
Apr 23, 2012 | Apple iPod nano 2nd Generation MP3 Player
Regular batteries die right away should I use only rechargable batteries
There is something wrong with your camera that is causing the batteries to run down quickly.
Using recharage batteries will not fix this problem as they too will run down quickly.
You need to get your camera services/repaired.
Apr 21, 2012 | Cameras
It is not charging,the charger is all right
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | FUJIFILM FinePix Z35 Digital Camera
Battery loss
Recharageable batteries tend to fail if left in a uncharged state for long periods and they fail to recharge. In this case the recharageable battery needs to be replaced.
Mar 21, 2012 | Creative Labs Audio Players & Recorders
Can I use rechargeable batteries with this camera?
No it won't, you can use recharageable AA batteries.
Nov 14, 2011 | Cameras
Internal battery needs replaced. the battery will not charge
the mother board battery is not a rechargeable battery it is normal battery to help your computer memories the time and date it almost got empty charge after 3 years
replace it very cheap and easy to do
May 25, 2011 | Computers & Internet
My advent verona turns off when the charger is unplugged it is 14 months old and has been minimally used ?
If a recharageable battery has been left in a low state of charge for a long time, the battery will be damaged and the battery life shorten considerably.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 19, 2011 | HP Pavilion dv9000z Notebook
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
Kodak EasyShare CX7530 Digital Camera Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
