After tub fills to about the heater level, unit stops filling and wash cycle does not start. Unit is still powered up, no flashing lights, all selected programs remain a steady red.
Drain will work, but no other cycle will operate.
Any suggestions, unit is only 18 months old.
My best guess is the door latch or door latch switch is not working properly. Once the unit is full of water try holding the door shut tightly if the unit runs by doing this check the top rack and make sure it is completely seated to the back. I have found a knife or fork tangled in the top rack and letting it seat, also the alignment of the water line for the top rack. If it does not run with what I have suggested, it will be time to start checking the mainboard operation.
I hope this helps
SOURCE: Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
SOURCE: Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
SOURCE: Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
SOURCE: Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
