Question about Polaroid TLA-01911C TV
Blank White screen - Polaroid TLA-01911C TV
Posted by Joseph Saccente Jr on
Buddy Mcsparrin
  • 1,684 Answers
A blank white screen is one of the symptoms of a failure in the power supply board. The power supply board is not putting out all of the correct voltages to power up the TV. These types of problems are caused by parts called capacitors. They filter the output power and when they die the power supply can not operate correctly. This is easy to repair if you can do a little soldering. Here is a link to a repair guide for this model.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-fla-01911c-with-a-bad-power-supply/
I hope this helps get your TV back running,
BuddyMc
Posted on Jul 15, 2012
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
How do I fix a blank white screen
Hello, another test is to connect a monitor to the VGA out or (other video option) and if the results is still a blank white screen then a repair is definitely needed.
Jun 19, 2014 | HP Pavilion dv6000z Notebook
There is a white blank screen when i turn on
A white blank screen usually means that there is no data reaching the LCD. This can be caused by a bad video card, bad cable, or bad LCD. Rarely, the cable is just unplugged on either the back of the LCD or on the system board (or video card if separate).
Apr 25, 2010 | Computers & Internet
Screen not working
Lisa-
I am sorry to hear that the new sidekick 3 is not working for your son.
Is the screen white, blank, or just hard to see?
If white, then the flex cable needs to be reseated.
How to fix a blank white Screen on a Sidekick
If dark blank, then reseat the lcd assy itself and see if it works
Reseat the Sidekick 3 LCD Screen
If hard to see the screen, then the backlight is dead. A new screen is needed for that.
Replace the Sidekick 3 LCD Screen
I hope that helps
Feel free to contact me if you have questions
Dec 15, 2008 | T-Mobile Sidekick II
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
White blank screen
Hi...there,
If you got a white screen, then you need to replaced a new AD board. AD board is a piece of component that you plugged your VGA or DVI cables to the monitor. Good lucks, Have a nice weekend!
Sep 11, 2008 | Relisys RLT1720 17" LCD Monitor
Blank screen
can be the flux contect(lcd to pcba flux)loose
can be debug by-assble again the flux
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Blank white display on Nokia 3230
This is a major fault, screen gets blank white because of some problem in its display panel which is right behind the LCD screen. Rush to the nearest Nokia care centre and explain the problem to them.After the repair if you experience this problem again and your phone is within the warranty period you can demand a brand new box piece!
Sep 03, 2007 | Nokia 3230
Polaroid TLA-01911C TV Logo
96 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
