Philips 10FF2CMI 10.2" Digital Photo Frame Monitor Logo
Question about Philips 10FF2CMI 10.2" Digital Photo Frame Monitor
When I am switching on the Philips Photoframe 10FF2CMI , no picture comes. Just a screen comes when has a line and a black leaf. Looks like the screen has got damaged.
Posted by anshumali_jh on
Anonymous
  • Philips Master
  • 6,771 Answers
If the screen is damaged it must be replaced, but before you consider that make sure there is no secondary problem.
Posted on Apr 10, 2012
Philips Photo Frame Failed to load executable file
Download the last Firmware-File from Philips and extract it. In the extracted folder is a file called execute.bin. This file must be moved over the Micro-USB-cable to the internal root folder. After a restart the photo frame should be automatically install the last firmware.
Does the Phillips Photo Fram spf3010c/g7 have any firmwar eupates?
Not that I am aware of.I own one and have not received any word from Philips.
I dont know how to edit my pictures.
Download the owners manual here. It will tell you everything you need.
http://www.generalmanual.com/Monitors/Philips-10FF2CMI-PhotoFrame.htm
Will I need a cable for my Philips PhotoFrame to conect to the computer?
No, the Philips PhotoFrame has a USB flash drive connector, you can plug-in a flash drive and transfer the pictures from that. No cables needed.
I have purchased a 8'' digital photoframe and it will not show the pictures on a disc from a Sony camera Ihave even tried puting it into a card reader. Please advise
The frame supports .jpeg still images. If the pictures are too big, it may not be able to scale them. Have you tried reducing the picture size and loading the trial pics on the frame? Try a .jpeg off the net. They should all work OK.
3helpful
Hiya, I have a philips photo frame 9FF2
It seems that SD cards bigger than 2 GB are not supported by this photo frame... I have the same problem tsssss...
I can't transfer photos from computer folders to Philips Photrame
ya it may a problem. pictures have different resolutions and aspect ratios.  Your cam may have the larget highest resoution wich is lower than the resolution of pic what you have in your comp.. hope it helpd you..:))
2helpful
Downloading pictures from pc to photoframe
First install the application which you receive with the picture frame on your computer. Connect the frame with your computer by using the USB cable. Once you have connected the frame, you will be able to see an additional drive in "My Computer". Just copy the pictures from your computer and save them in that new folder.
In some software, which come with the digital frames will create a program by themselves after the installation. In these case, you need to open the program and then connect the photo frame to the computer. After connecting, you will see that the frame will synchronize with the computer and you will see that the program which you have already opened will show you the drive of the frame, where you can just transfer the pictures from your PC to the frame.
2answers
I bought a photoframe-10FF2 series. I have a pc with lot of pictures-I want to transfer them--I have not been able to-please help
My philips Photo Frame does not work. It just get the "Please Wait" message when I start the photo frame. But nothing happens after that. Can someone help me please. I have reset the button, but nothing happens.
Thank you much...
Top Philips Computers & Internet Experts
Marvin
Marvin
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
