Question about Epson Cameras
Storyteller software not working with older files
My Storyteller software (updated) does not open older files, or opens them and loses the text, or opens and puts in an extraneous photo box in upper left corner. I have 3 computers and am having the problem on all 3...2 are Vista and 1 is XP. Have previously created albums to print, and can't access the work correctly. This includes an album created as recently as August and September. Have uninstalled and reinstalled enough times to drive a person crazy.
5 Suggested Answers
adonscott
Guardson Nunez
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: I seemed to have developed
Normal 0 Are you using Windows Vista? If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
In your case look in the different Key setting drop downs and find which on has the period set and change it or DISABLE it.
Hope this helps. Bud
Posted on Jan 15, 2009
asthanarht
rohit asthana
  • 258 Answers
SOURCE: western digital external hard drive showing empty folder
ya difinalty you are thinkg in right way....actually last folder is not copied properly.....
Posted on Mar 29, 2009
Ty Price
  • 11967 Answers
SOURCE: My Nikon Coolpix L18 wont allow me access to the Photos
Use a card reader to download your pics.
Posted on Oct 29, 2009
SOURCE: unlock code for adobe photoshop album
Just google by typing "adobe photoshop cs3 keygen".that's it.there are 1000's of sites where keygan can be downloaded they are free to download but at the cost of infecting the system with virus,worm,malware etc. as those sites income comes from hosting those viruses.
I recommended you to buy the original software from any Local authorized vendor.
Posted on Dec 23, 2009
Powerpoint can't open the type of file represented by........
1. Try some of the things listed below. But first make a backup copy of your presentation and use it, not your original file. Never try any of these recovery techniques on your only copy of a presentation.
Things to try:
-If you run PowerPoint 2003, choose Help, About Microsoft PowerPoint from the main menu bar. If the About screen doesn't indicate that you have SP1 (Service Pack 1) or higher, you should update your copy of PowerPoint. Choose Help, Check For Updates. When the Office Downloads page opens in your browser, click "Check for Updates" and apply the recommended hotfixes and/or service packs.
-If you run Windows XP and have installed SP1, see Files open as Read-Only after installing Windows XP SP1, Other file/path related problems
-Open a blank presentation (You can apply the template used for the damaged file, if applicable. That might help cut down on reformatting.)
-From the main menu, choose Insert, Slides from File (or if you use PowerPoint 2007, Home tab, New Slides (bottom of button), Reuse Slides.
-Try to insert slides individually if you're not able to insert the whole thing
2. If your file became corrupted when PowerPoint or your computer crashed, there may be a temporary version of the file in your TEMP directory. If so, you can try the aforementioned Insert, Slides From File and browse to that file. Or you can try changing the file's extension to PPT and see if you can open it from within PowerPoint using File, Open. You could also do a search for *.TMP files on the off chance that it's not in your TEMP directory.
3. If nothing else works, try opening the presentation in Word to see if you can at least recover the text:
-Start Word and choose File, Open
-Choose file type "Recover text from any document"
-Edit the file as needed
4. If all these three methods don't work, then use third party software PowerPoint Repair Toolbox https://www.repairtoolbox.com/powerpointrepair.html
Apr 13, 2015 | Microsoft PowerPoint 2007 for PC
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
Download Epson StoryTeller Publisher software
hi you should give us the full name of your epson machine then i will give you the link of the software
Jan 24, 2013 | Computers & Internet
My dvd is not working on my blue ray it saying go to update some software
you will need to download the update from
http://pages.samsung.com/us/bluraysupport/support.html
how to - make an update CD
  1. Download the software update file for your hardware.
  2. If the update is compressed (zip file or rar file), the file should be uncompressed before burning.
  3. You must burn the update file on a blank CD-R/W disc by using "Burn Image" option.
  4. Burn an image file of the software update file (*.iso)
how to - update your player with your CD
  1. Press OPEN/CLOSE to open the disc tray.
  2. Insert the update CD-R disc with the software update, label facing up.
  3. Press OPEN/CLOSE to close the disc tray.
  4. Wait 1-2 minutes until the screen displays "Verifying Firmware version..."
  5. After checking old and new version, select "Yes" or "No" with "?" or "?"
    on the remote control. If you select "No", BD-P1200 will be powered off in a state of tray open.
  6. Press ENTER button on the remote control.
  7. Remove the update CD from the tray.
  8. Screen will display "Firmware Update Now Processing... Please do not turn off the power".
    This process will take 4-5 minutes. When done the screen and power will turn off automatically.
  9. Turn the unit on again with the power button. They tray will close automatically and a
    Menu Language Selection screen will open.
  10. Select the Language you want by pressing the corresponding number button.
  11. Update is complete.
Jan 15, 2011 | Samsung BD-P1500 Blu-Ray Player
I can't open SYLK file
are you trying to open a txt file or a comma-separated variable (CSV) file and i bet the chances of the file name having a capital "I: or "D" are good huh.
To open your file in Excel, open the file in a text editor, and then insert an apostrophe at the beginning of the first line of text.
How to Insert an Apostrophe
To add an apostrophe to the beginning of the first line of text in your file, follow these steps:
1. Open the text file in a text editor, such as Notepad. Click before the first character in the first line of text. Press the APOSTROPHE key on your keyboard (').
2. On the File menu, click Save. Quit the text editor. You can now open the file in Excel.
hope this helps , next time tells us the version of your excel and what operating system you are running.
Mel
Jun 11, 2010 | Microsoft Excel for PC
Scan document to text
In order to scan to text or pdf, we need to install OCR.
Please follow the below steps to install OCR.
Please open the link and click on download only.
Once we click on download only, we will get an option to save.
Please save it on the desktop and then run.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=oj-72836-2&cc=us&lc=en&dlc=en
.You will get an eror message that says "This update does not support any of the HP device drivers that you have on your PC. You do not need this software update
Please do not close that window.
Now, please open the temp folder by performing the steps given below.
: Press and hold the windows icon button ( between the ctrl and alt buttons on the keyboard ) and then press the R button.
: Run window opens up.
Type %temp% in the box and press enter.
I would request you to perform the steps to open the run window and type %temp% in the box and press enter.
The temp folder opens up, once that is done.
Please open all the 7z folders and locate the OCR_webpack folder
: Plaese copy the same folder ocr_web_pack and paste it on the desktop.
Close all the windows.
Please click on OK or cancel the error message.
Now, open the OCR_web_pack folder that you have pasted on the desktop.
Double click on the .exe file found in the OCR_web_pack folder.
This should start installting the OCR software in the computer.
You will get the options, Help (folder), Licensing(folder), Setup(folder), Autorun, hpqbpl1.dat, hpzsetup, setup.
: Open the setup folder.
: You would find the OCR setup.exe file, or set up foler or set up file, double click on the same to start installing the same.
Once the installation is complete, we will be able to scan to text.
May 10, 2010 | Office Equipment & Supplies
I have a windows vista that had Microsfot office home and student 2007 pre installed. I did open up the trial version and used it for a project. well it has been long expired and every time i save...
You won't lose the data files, but you bring up a good point. I would use Word Pad and try opening a couple of the files. If they open correctly, you'll be safe to uninstall MS Office.
If it doesn't open, try to convert them to a simple text file or a .rtf file in MS Office by opening them and choosing Save As and save them that way.
Oct 27, 2009 | Microsoft Office Professional 2007 Full...
Problem
It sounds like your computer shut down while the file was open, and the software saved it by default. If this is what happened, then you would get the "text recovery" message when you opened the software again, after the computer re-booted. Have you tried opening the file using the link within the "text recovery" message?
Apr 06, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Powerpoint opening
When you double-click the file in Windows Explorer, the file opens correctly.
To resolve this problem, install new update for your version of the Office program.
OK/
Dec 09, 2007 | Microsoft Office Standard for PC
Cameras Logo
48 people viewed this question
Top Epson Cameras Experts
Peter DiGiovanni
Peter DiGiovanni
Harrie
David Hoff
Are you an Epson Camera Expert? Answer questions, earn points and help others
