SOURCE: SYSTEM ERROR E000 on Canon I-SENSYS MF 4690PL.
Hi flord, this error code on CANON, (E000) means that the Fusing unit not heating up, the mostly of cases this unit is damaged and need to be replaced.
you migth contact canon support to replace the fuser of the printer. maybe you have printer too many sheets.
SOURCE: I need Driver for canon
Click here Click on above link download driver for your os . Let me know if you need further assistance. Thanks for using FixYa.
SOURCE: how to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in luck
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that error let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
