Casio Algebra FX 2.0 Calculator Logo
Behzet Posted on Apr 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello im running a program where there is a list. The calculator is stuck in the middle of the program!!No botton works ??what should i do ?
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Apr 09, 2012
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4673389
Points
21595
Press the Exit key to quit the program. If that does not work, try pressing the AC button. Try also the Menu key. If all fail, force the calculator to RESET itself. Use the tip of a pen to press the Reset button.
Program fx 7200g
What is the question?. If you want to learn how to program it, you should download the manual from world casio site. Select calculators, manuals.
If you are looking for programs to run on the calculator, check this web site
It has a collection of activities with program listings you can enter on the calculator.
1helpful
While running a program, an error message which says "protected memory violation" was displayed and the calculator stuck and i can't do anything.i cannot close,reset it nothing.can you help...
Application functions cannot be called from within the application. If you try to call a function using the
application's problem-entry dialog boxes, the error message, Protected memory violation, will appear.
Exit and re-enter the application to ensure normal operation.
How can start to do the program in ti-89 im study civil engineer, and a have programs in fortran
You can find the program editing menu under "Apps". Choose "New..." After you enter the name of your program, you will be able to edit it. To run it, go to the home screen (the screen where you enter mathematical equations), hit 'catalog', then 'f4', and choose the program from the list.
As for the coding itself, this site has a solid reference of many concepts and commands that are involved when programming for the TI-89: http://tibasicdev.wikidot.com/68k:home The best way to learn, however, is to play around and figure things out yourself. Programming for the TI-89 is much more powerful than it is for the previous TI calculators. Best of luck!
2helpful
How do I get newtons method into my calculator?
Press [PGRM] [|=>][NEW][1:Create New][ENTER]
At the prompt NAME=, Type the name of the program.
Use the catalog [2nd][CATALOG] to enter the commands Input, Lbl, nDeriv(, Disp, Pause, If, abs(, Stop, and Goto.
In the catalog, the entry mode is ALPHA
  1. The fisrt two lines of the second screen are not to be entered. (It is an overlap). I had to scroll down to get to the bottom of the program editor screen.
  2. Before you can use it to solve for the zeros of a function, you must define it in the [Y=] editor.
  3. The symbol Y1 in the program listing can be entered by pressing [Vars][|=>Y-VARS][1:Function][1:Y1].
  4. When finished entering the program press [2nd][QUIT] to exit the editor.
To run it, press [PGRM]. Under the menu [EXEC] you see a list of the available programs. Select the one you want and press [ENTER]
During the run, the program finds an iterate and waits (Pause) for you to press [ENTER]. You must keep pressing [ENTER] after each iteration, until it returns Done.
Hope it helps.
Thank you for using FixYa.
Do not forget to rate the solution.
When typing on a ti-83 i couldnt go up to see older work. fix it.
The only way you can enter text in the TI83PLUS is through the program application. However, I have a hard time understanding what kind of funny story is worth typing with such an awkward, uncomfortable excuse of a keyboard.
Joking aside, if your text has been saved you can access it as follows:
Press [PGRM][EDIT] and select program name in the list.
Hope it helps.
2helpful
Random symbols and/or dots all over the screen, cursor in middle of screen an turns off randomly
1. Press [2nd][QUIT] to interrupt any program that may be hung in memory such as games run under MirageOS.
2. Clear the screen by pressing [CLEAR].
3. Reset memory [2nd][MEM][7:Reset][1:All Ram][2:RESET] [ENTER]. ram cleared appears on screen.
4. Press [CLEAR] to go to Home screen.
Hope it helps.
3helpful
2answers
Error in running program
I agree with the previous solution and would like to add if you declare your variables using the local command then they will only reside in that program.
:prgm
:local db, e, plus other variable used in your program with a comma to separate them.
:prompt
And I think what the above solution is saying is to :Disp "k",k would work better.
I hope you used the Ti commands and not the ones you spell out on your listing, if so you might want to check them too. The store command I can understand why you typed it out.
I like the fact you want to program so remember fixYa to help you develop your programming.
20helpful
Ti-83 plus is frozen in the middle of a calculation.
This just happened to me. Running my fingers over helped because the problem was caused by a 'stuck' key. Sometimes it is clearly stuck to down but othertimes it is pretty hard to tell. Regardless when a key is pressed you can't press any of the others until it becomes unpressed.....so one thing to try is to hit the back of the calculator until the keys are all unstuck.
SCREEN PROBLEM
Hello fezzaniaahmed. Im sorry to inform you no parts from TI for the TI-82. You may find another TI-82 with a different problem and 1+2=1. Good luck.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
