Question about Toshiba CF35F50 TV
CF35F50 SET WILL NOT POWERUP, IT WILL CLICK AND THE RED POWER LIGHT COMES ON WHEN YOU TRY TO POWER IT UP, ALSO HAS A 15" BAR THAT DISAPPEARS AFTER AWHILE, WHAT EVER IT IS SEEMS TO BE INTERMITTENT, BECAUSE IT WILL POWER UP AT TIMES AND THEN THERE IS TIMES WHEN IT WILL NOT POWERUP FOR DAYS, WHEN I TURN OFF THE POWER SWITCH WHEN THERE IS NO PICTURE OR SOUND, IT FLASHES OFF
SOURCE: Toshibe CF32G50 - Red Flashing Light
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Posted on Jul 15, 2007
SOURCE: No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
Posted on May 03, 2008
SOURCE: toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Posted on Sep 29, 2008
SOURCE: red light blinking no picture no sound
tart checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In
that case the fault can be either the audio board (often audio circuit
is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
Posted on May 22, 2009
SOURCE: screen will not turn on, power light flashes red
try checking first your tact switch or your power button, then next look for open fuses or low ohm resistor on secondary part of your power supply then check your horizontal and vertical outputs for shortage and open circuits check also your horizontal drive stage.
Posted on Oct 14, 2009
Feb 09, 2016 | Audio Players & Recorders
Dec 25, 2013 | Samsung LN32A330 32 in. LCD TV
Sep 23, 2013 | Toshiba CF35F50 TV
Dec 06, 2012 | Televison & Video
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Aug 06, 2011 | Toshiba 55H70 55" Rear Projection...
May 02, 2009 | Televison & Video
Mar 20, 2007 | Toshiba CF35F50 TV
Dec 06, 2011 | Toshiba CF35F50 TV
43 people viewed this question
