SOURCE: remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
SOURCE: manual code to program remove for panasonic pv m2023
The remote control for Panosonic model 2023 does not work from a distance. But it works close by
Can you help?
Soundar
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
SOURCE: can't find comcast remote codes for panasonic
Most universal remotes will not work with TV/DVD/VCR combos . Sorry!
SOURCE: What is the universal remote code to program a
ask at manualfox.com/remote.htm
they will figure it out
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
