I moved and had my hp a1330n in storage for the last 6 months and i got it out hooked up everything works fine except when cable guy hooked up internet he said ethernet port might need replaced. wifi works fine
If the card from the other pc fits the slot, then it should work fine. Look at the card before you install it in the 1330n and note the model number in case you have to download a driver for it. You can also go to hp.com and search for the network card driver for the m7650n. Let me know if you still have problems with it.
Joe
SOURCE: Internet Connection Issues
Very well could have toasted you network card. If everything else works, try installing a different one (and drivers) that is known to work. MM85
SOURCE: monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
SOURCE: I have a replacement power supply for a HP IQ770
it is in the mother board but please be carful with this connections
SOURCE: my hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
SOURCE: I have a HP Pavilion s7320n PC, It won't turn on.
open up the chasis and connect the cable coming out of the smps and going to the motherboard properly
ok I misunderstood wy wife talke to him he said it needs a nic card so if thats is network card can i use one out of an hp m7650n?
