Before i replaced the bulb i tried unplugging it and plugging it back in and a few other things. Everything would come on and run like they were supposed to. Then i replaced the bulb since thats what the lights had indicated needed to be done. When i got the bulb in and plugged the tv back in nothing would work. No fans or anything. Is there some sort of reset process or anything i can go through.
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
SOURCE: Hitachi Model 50UX57B
This problem was posted almost a year ago. Do you still need help or has it been fixed or replaced?
SOURCE: Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
SOURCE: Hitachi 50v710 Yellow spot
I found out that Hitachi has a class action law suit against them for the light engine problem. I called them and asked what they were going to do for my tv which is out of warrenty. The reply was that they would pay for new light engine. I said what about labor. No they would not pay for labor. I asked to speak to supervisor. I was told by supervisor that the tv had to be inspected by certified repair person. Cost for this was $125 but would be applied towards the total labor cost. Repair guy came to house walked in and said he did not even have to turn tv on to know the problem. We called Hitachi to set up shipment of part. Hitachi told me at that point that they would cover all labor costs also. Part has been installed this week and tv is like brand new set.
SOURCE: Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
