Need factory settings for carb screw has one screw and one idle screw
SOURCE: Homelite
Go to www.homelite.com then in the red up top click on order parts then click launch to parts catalog then scroll down to accept agreement and then you will need to enter your model # and then you can go thru the list of breakdowns and get your part # from the diagrams.
SOURCE: weed eater wont start,put straight gas in it.
if you didn't mix any oil with the fuel,you probally burnt the piston and cylinder up.the only to find out if you did is to pull the muffler off and look inside the cylinder and see if there are any scoring on the piston.if there is you need to replace the piston and cylinder assembly.most cost $100.00 or more.usually they are not worth repairing.i know this is not good news but i hope this helped,let me know.................
SOURCE: Homelite 26vt Mighty Lite carb settings
Setting up the carb right on a trimmer is like setting one up on an RC gas operated car. It takes someone with a good year,and a lot of experience doing it. If youre new at it,youre not just going to be able to get it tuned,well you could,if you want to spend a few hours. Just take it to someone who does it,they wont charge you much and it will save you a lot of aggrevation.
SOURCE: need a new carb or a rebuild kit for myHomelite
The carb will be either a walbaro or Zama carb. Take the carb to your local power equipment shop and they shoud be able to provide you with a carb kit
