Question about Packard Bell Audio Players & Recorders
Packard bell eclipse boot error 1
Boot error
Posted by gie_wyckmans on
5 Related Answers
Anonymous
  • 1913 Answers
SOURCE: packard bell computer does not boot
reset your bios settings put away cmos cell for 15 minutes .also u can reset your bios with jumpoer settings.
check your RAM refix again after clear it and its slot.
Posted on Nov 01, 2008
Anonymous
  • 849 Answers
SOURCE: My packard bell laptop requires a boot up cd-rom
put the bootable xp cd in your cd rom then turn it on. it will boot up automatically if the cd will be bootable and your boot sequence is correct.
Posted on Nov 19, 2008
Anonymous
  • 32281 Answers
SOURCE: need to make laptop notebook packard bell dvd region free locked on o1
You can only change the region code up to 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play any region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
Posted on Nov 24, 2008
Harrel Abalo
  • 107 Answers
SOURCE: packard bell e1245 crash
try press f5 when system is starting up then go safe mode, then try to restore your system to earlier setting with system restore. system restore is located on start/accesories/systemtools/system restore.
Posted on Mar 05, 2009
Anonymous
  • 10 Answers
SOURCE: i havea packard bell imdeia and the bios are messed up
i cannot be sure because i have never seen inside this type of computer, but it should be the same as any other.
on a normal motherboard there are 2 ways to reset the BIOS, the first of these is to remove and then replace the cmos jumper. the second is to remove the cmos batterry wait 5-10 minutes and then put it back into its slot.
i prefer the second method as it is easier and removes the confusion and mess of jumpers.
once the case of your computer is off the cmos batterry should be easy to see, it looks like a watch batterry and is about the size of a 10 cent peice. normally you will require a small flat head screew driver to remove the batterry
Posted on Oct 13, 2009
Packard bell ixtreme 9087 keeps powering off after boot up
Maybe it is not getting cool enough cause the cooling fan is not working. You need to provide more info about at which point of booting up, it gets shut down.
2helpful
2answers
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
1helpful
I have a Packard Bell iMedia SL 9553, The odyssey Boot Floppy has been lost, Any Way I could get a copy to restore the computer using the Master Discs I have?
YES YOU WOULD BE ABLE TO Call packard bell and show them proof of purchaase and get them sent out to you now packard bell was bought out by hewit packard and there number is or you could go to this website and get any driver you would need http://list.driverguide.com/list/company788/
HI THERE MY PACKARD BELL 2215 IMEDIA WILL NOT BOOT UP. iT WAS WORKING PERFECTLY THEN IT CRASHED NOW IT STARTS, FANS SOUND, BUT THEN IT SWITCHES OFF, ANYONE HELP? X
Sounds like an overheating problem. Clean the dust out of it, make sure it can get air on all sides, make sure the fans are turning. If that doesn't work, unplug the computer, hit the power button 20 times, wait 1/2 hour and boot it up.
My packard bell model number qua-k1
go to cmos setup and disable "1 boot lan"
1helpful
Packard Bell error signals
here is a list of packard bell beep codes with meanings
http://www.uktsupport.co.uk/pb/mb/phnxcode.htm
Hope it helps you
Doesnt boot up
Hey, Blackchuck, try this
When you power up, try to get into BIOS and see what you get.
Let me know and we'll go from there.
Ron-
Top Packard Bell Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
