Nintendo Super NES Console Logo
Anonymous Posted on Apr 08, 2012
Strange missing pixels/ discoloration for SNES
My Super Nintendo console diplays the games that i put into them, however some of the sprites are missing pixels and many of the colors are distorted. I've tried using a different television as well as different display cables. I also tried using an alcohol/water solution on the SNES's connectors. It used to work without problems mere months ago but now any game I try yeilds the same results.
  • Anonymous Apr 08, 2012
    I understand the console is old, but I am more looking for what I may need to clean/replace on the system rather than having to buy a completely different system
Anonymous
Level 2:
Champion:
  • Expert 231 Answers
  • Posted on Apr 08, 2012
Anonymous
Expert
Level 2:
Champion:
Answers
231
Questions
Helped
53375
Points
367
Hi the prob is the snes system itself its getting worn out
3 Related Answers
Anonymous
  • 121 Answers
  • Posted on Jun 04, 2010
SOURCE: How do you fix a bad video chip on a super
You could outright replace components. I know it's not the easiest thing to do, but it may very well be your only option.
Anonymous
  • 894 Answers
  • Posted on Aug 23, 2011
SOURCE: Hi I'm having a problem
Well It might be the gamepack but the only way to test it out is to try it one a different N64 console to see if you have any luck if it works somewheres else than your N64 console has an internal problem of it 0 luck on something else than Its a fake gamepack because the old consoles will reject fake game packs then.
Anonymous
  • 291 Answers
  • Posted on Sep 29, 2011
SOURCE: I've recently bought a new Nintendo 64 (used
Well I think that you have purchased a bad system buy stuff from Lukie or JJ games because they are reptauable sellers then.
4helpful
Why isn’t my Super Nintendo consoles red power light turning on while the ac adapter in plugged into the outlet on the wall ?
I am having the same problem with my super Nintendo console not having the red power light coming on. It could be the ac adapter that is causing your SNES console to not be turning on. You could try a new SNES ac adapter to see if it works or not. If your SNES console still is not coming on with a new ac adapter it maybe be the fact that your console is not working anymore and it would be more cheaper and easier to buy another SNES console than to fix the current one that you have. Lukie Games and DKOldies and East Starland games and JJ games have SNES consoles.
My nintendo 64 game pack will not fit into the slot of the retoduo
YOU CAN NOT PUT NINTENDO 64 GAMES INTO SNES or NES SLOTS. The retro duo is snes (super nintendo entertainment system) and nes (nintendo entertainment system) only there is not spot for the nintendo 64.
How do you open up a nintendo super nes console?
the SNES uses a special nintendo bit, you get 2 in a set the larger one will open the SNES and the Gamecube, the smaller one is for NES carts
Silverhill Tools ATKNND Security Screwdriver Bit Set 3 8mm and 4 5mm...
1helpful
2helpful
Snes reset button
Well you could try buying a broken Super Nintendo console off of EBay and get the part that you need to be replaced. If you find a broken SNES console with a reset switch button that is fine then.
When i plug my snes to my tv it wont work :/ i plug the cable to tv and put the snes on chan3 then i go on channel 3 with my tv and it show me a black screen ,sometime i hear 2 sec of the game music :/
Hi pikapike,
I see you are going back to the 90's with your Super Nintendo. Firstly I do not know how you can "put the snes on chan 3". If I am correct, all super nintendo cables to the TV are RV coloured ones. therefore once it is plugged into the TV, you will ant the A/V channel? which usually has a separate button.
Secondly if what you say that you get a flash/glimpse of the game, then check the system of your TV. Is it PAL (Europe, Aus, NZ, etc) or NTSC (U.S.) Hopefully you can change the TV settings to match your game console!
Hope this helps,
kamacosmic
My SNES was working while i was playing a game, i shut it off to put in a different game, and when i turned it on, it wouldnt work. any suggestions on what to do?
i to love the snes, i suggest to get a wii, softmod it, then install all your favorite snes games on it via wads. all your games will show up as channels on the wii and they play flawlessly. (no lagg) all you need is a classic controller or gc controller
My snes keep showing pixels when they are not supposed to be there
Clean the game cartridge with a qtip and some rubbing alcohol, swab the game cartridge board on both sides (don't touch the grey plastic, only the circuit board) and allow to dry before reinserting it into your SNES. This problem is due to a dust and dirt inside your game
SNES not working with Street Fighter Alpha 2 (graphic chip)
I'm not sure what a pin card is, but my best guess is that the game is dirty?
Super Nintendo games start but levels don't
try blowing inside the game cartridge and then the slot the game inserts into. I had this problem on my snes with some games and this helped. Other to that it may be the console is on its way out.
Ebay sell some really cheap snes consoles now. I picked one up for £15.00 with games.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
