Televison & Video Logo
Hi, I have an alba lcd32880hdf tv and moved tv to different part of room, when I turned the tv back on and did auto tune channels came back up except itv ones so went to retune again but tv then came up as a blue screen saying no signal
Posted by bernie_carey on
Anonymous
  • Televison & ... Master
  • 6,771 Answers
The Tv is working fine, from the description it is that one channel not coming in, the blue screen indicates no signal. It could be that the signal in that room is a little weaker and just going below the thresh hold to allow it to come through. It is possible the station might have been off the air, try another auto tune.
Posted on Apr 08, 2012
5 Related Answers
ladybird1939
SOURCE: poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Posted on Dec 27, 2007
Anonymous
SOURCE: setup for coby tv-dvd 1350
I need to download the instruction/manual. Can someone direct me?
Thanks
Posted on Oct 29, 2008
Anonymous
SOURCE: can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Posted on Mar 29, 2009
Anonymous
SOURCE: Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Posted on Oct 10, 2009
barbu51
Jacques Marin
  • 566 Answers
SOURCE: Under signal information I've got bit error level
Hi zaikovskis
I`m going to help you with your tv but first; could i have the brand name and model number?
Should be written on the back of the set.
Posted on Mar 31, 2010
Alba LcD32880HDF. How do I reinstall free view channels.
Try here;
https://manuall.co.uk/alba-lcd19880hdf-lcd-television/
Page 19 is the stuff you'll need.
You will need an aerial plugged into the TV to receive the DTV signal in the first place.
Best of look.
Cannot tune in my 19 inch Alba tv to main channels ie bbc and itv
POOR AERIAL SIGNAL, CHECK THE COAX JACK IS ON PROPERLY. NO OUTER STRANDS OF WIRE SHOULD BE TOUCHING INNER COPPER CORE. OR CHANGE CABLE & GO INTO THE BACK OF A SKY BOX TO THE TV, THEN RESCAN.
1helpful
How do you auto tune the Radio channels in or even do a search for different channels?
get the on screen menu up ( press menu on the remote) move around until you find auto tune , move sideways and it starts auto tuning
ti finds all radio and tv stations for you
when finished it may auto save or you will be required to press the ok button then exit
Hi have a built in freeview alba tv tune in channels working fine but dont have any bbc or c4 c5 any one can help me or send tv back
Can't tune Alba LCDW16HDF :( - Freeview - Digital Spy Forums
forums.digitalspy.co.uk/showthread.php?t=1238173
Digital Spy
Apr 1, 2010 - 17 posts - ‎8 authors
No matter what the problem DS Forum posters will always provide an answer ... That the Alba is your only digital television receiver - you don't have another ... I suspect the set may have found Craigkelly's BBC & ITV/C4/C5 ... BBC Three questions? - Broadcasting
Dec 13, 2015
Why dont RTE do this - Page 2 - Broadcasting
Aug 21, 2015
Channel 4 Licence Renewal and Scotland - Broadcasting
Mar 12, 2014
Why Won't Freesat/BBC let Viewers Nationwide have ...
Jan 20, 2014
More results from forums.digitalspy.co.uk
Freeview Help: Missing Freeview Channels - Radio and Telly
Alba lcd32880hdf has lost colour when watching Tv but works when using games console
It is almost for sure a bad connection at you wires. To show in black and white means your red and green are reversed or bad. I am guessing you have this hooked up with component.
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Not sure if anyone has come across this problem before. I have had 3 tv's in my son's room and all 3 different models including old one alba 19 inch lcd and another all just stopped working....
jotvguy just wondering, is there definitely power in these outlets ? Have you tried a lamp or something else to prove you have power at the wall outlet?
Top Televison & Video Experts
Marvin
Marvin
