Question about Life Fitness Exercise & Fitness
Where can i find a seat for avanti is400 rowing machine?
Posted by belcy fernandez on
unknown
From Avanti, eg. Workoutworld; they own/operate the Avanti fitness retail brand. Workout World Australia or Workout World US
Posted on May 17, 2014
1 Related Answer
Fissh Taco
  • 28 Answers
SOURCE: where i can find a seat for avanti is 400 rowing machin?
if you are looking for a seat for a rowing machine i would suggest checking amazon.com, craigslist, and ebay. I think that you will find what your looking for
Posted on Apr 09, 2012
Plastic roller under seat support to allow movement avanti is400
What is your question ? Adding more specific detail information about your vehicle would also help. Like, year, make and model
Nov 27, 2016 | Seat Cars & Trucks
I need new bearings for seat of body sculpture rowing machine br 3050
Remove the bearings and take them to your local Industrial Supply retailer, they should be able to cross reference and get you the ones you need.
Feb 24, 2015 | Exercise & Fitness
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
May 24, 2017 | 2003 Ford Expedition
Where i can find a seat for avanti is 400 rowing machin?
Apr 08, 2012 | Exercise & Fitness
Replacement wheels for voit rowing machine
I have a Voit RM 4 rowing machine, and the 6 plastic wheels under the seat are dried up and broken. Any one know of a replacement option?
Oct 10, 2011 | Exercise & Fitness
Computer replaced batteries - screen lights up but does not function when rowing - not registering meters
Check the mtion sensing magnetic switch thats under the seat rail. It determines if you are rowing and sends a signal to the computer. Make sure all connections are fully seated. You may have loosened a wire when you swapped the batteries.
Feb 24, 2011 | Concept2 2 Rowing Machine
Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
May 06, 2009 | Kettler Coach Rowing Machine
Machine does not register when rowing
You most likely moved or damaged the senser under the seat check if the wire is loose or damaged the the senser it in the center of the bottom side of the seat Good luck
Apr 16, 2009 | Exercise & Fitness
Exercise & Fitness Logo
205 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
