Question about Vivitar 283 Flash
Can I use a vivitar 285hv on a canon 10d using the PC connection?
Posted by Ronald Simons on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The trigger voltage is right on the border line. Take a look here.
Posted on Apr 08, 2012
5 Related Answers
Anonymous
  • 667 Answers
SOURCE: Will a Vivitar 285HV fry my Canon EOS 40D?
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Posted on Jan 08, 2008
Pengzireman
  • 3 Answers
SOURCE: Vivitar 6000CAF for Canon EOS doesn't seem to work on my Canon 30D EOS camera?
A more appropriate product is Suntax DRF14C for Canon 10D, 30D.
http://www.suntax.com.sg/DRF14.html
Posted on Jan 21, 2009
Anonymous
  • 17 Answers
SOURCE: No power for my 'old' Vivitar 285HV Flash
I've got three 285HVs and have had this problem. Obviously, make sure the batteries are good and the door and inside terminals are not corroded. The whine sound that you usually hear is the high voltage circuit. the reason it changes pitch is that the main capacitor is charging. As the charge gets greater and greater, the pitch with go up as the circuit changes the power being fed to the capacitor. If you don't hear the "whine" then it's either the HV circuit isn't working (probably not) or the capacitor has gone bad. These things are sealed but can decay internally due to their structure. Usually this is due to the dielectric components breaking down or the electrolytic goo drying up (usually what causes it).
Sometimes, you can let it sit with good batteries and the switch on to see if it will eventually start to charge the cap. Most of the time tho, this is an indication that the capacitor or the charging circuit is dead. It can be repaired but sending it off will usually be more expensive than replacing the unit.
Be sure and rate me!!
Posted on Feb 09, 2009
  • 102366 Answers
SOURCE: what's the trigger voltage of Vivitar DF283?
According to http://www.botzilla.com/photo/strobeVolts.html the newer ones made in China or Korea are in the "Your call" range, about 5V to 10V. The older ones can go as high as 600V.
Posted on Apr 15, 2010
bhargav
  • 66 Answers
SOURCE: My one year old vivitar 285hv flash fires
PC cord might get minor short circuit and got faulty.
You can confirm this by removing it.
Posted on Jun 29, 2010
How to remove sensor from Vivitar 285HV Flash
Pull it straight out from the body. See the instructions on page 9 of the manual.
Oct 22, 2012 | Vivitar Used Replacement Vari Sensor...
Can I use the vivitar 285HV flash for a canon S5 IS?
The 285HV should be safe with modern digital camera. Its trigger voltage is specified as 12V max.
Feb 21, 2012 | Canon PowerShot S5 IS Digital Camera
I have a Vivitar 285HV flash and I'm wondering if the firing voltage is low enough to use with a Canon Rebel Xs digital camera?
According to Vivitar, the 285HV has a trigger voltage of 12V, which should be safe for use with modern digital cameras.
Mar 22, 2011 | Vivitar Cameras
My one year old vivitar 285hv flash fires intermiiently (every 3 or so flashes) when the flash is connected by pc cord??
May 20, 2010 | Vivitar 285HV Flash
Can i use vivitar 285 hv flash with my canon powershot sx10 ?
It is the HV version, yes you can just put it in a color mode so the sensor on the front guesses the out put- it isn't ttl so it won't know what the camera is thinking
Feb 27, 2009 | Vivitar 285HV Flash
Can I use my Vivitar 385 with my Pentax K200?
Yes, you can use the flash if your camera has a PC connector.
Or, check the trigger voltage: under 7VDC = OK on hotshoe.
[email protected]
Oct 31, 2008 | Vivitar 285HV Flash
Apr 01, 2008 | Vivitar 6000AF for Canon TTL Ring Light...
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage...
Jan 08, 2008 | Vivitar 285HV Flash
Vivitar 283 Flash Logo
41 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Barbat Nae
Barbat Nae
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
