Hi, i got the same problem as this fella here: http://www.fixya.com/support/t7763563-got_problem_226bw_samsung_some and i want to try and change the bad caps. Problem is, i dont know which ones to buy. Im a rookie and doing this, but i believe i can do it. Im from denmark so i need to find a place to buy it that ships international. Thanks in advance!
Usually the capacitors are 1500uF/25V and 470uF/25V, but I suggest to use 35V capacitors. This will make your power supply to last forever. Also, you better open the monitor and see by yourself what kind are the capacitors. Mind the polarity or the capacitors will blow out with lot of smoke. You can buy them from local parts store like Conrad.com or online.
Testimonial: "Okay, this was really helpful, thanks a lot! "
SOURCE: Samsung 226BW 22" LCD has gotten worse!
As stated in your previous post, this can be fixed with some minor electrical and soldering knowledge. If you do not have the knowledge yourself, you will have to find someone to do it for you. The parts wont be expensive, but I do not know what your local repair shop would charge you for the labor.
Nothing else you can do with the exception of buying a new one :-(
SOURCE: Monitor darkens significantly when viewing some
The monitor might be on 'dynamic contrast'. Press menu on the remote control and does it say that 'magic bright' is on dynamic contrast?
If so, change it to something else and this may solve your problem.
Hope this helps!
SOURCE: Hi, I got problem with my 226BW Samsung. Some
Sorry, the links you provide does not work. You can post the picture her at FIXYA but it has to be less than 150k in size. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Do you see caps with dome top (not completely flat)?
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Testimonial: "Thanks for your help"
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Just wanted to add, i use this screen as a secondary screen. Only way to make it work is to wait like 15 min then press the source button 10-20 times untill it turns on. Power led still blinks when its black screen. But im still able to turn it on after some time.
Its a Samsung 226BW like the post i linked :)
