my phone is a binatone fusion 2200 i have a pic of a message on it and the green light is flashing but i don't know which number i have to dial to retrieve the message ?my phone is a binatone fusion 2200 i have a pic of a message on it and the green light is flashing but i don't know which number i have to dial to retrieve the message ?
You can't post conmments that contain an email address.
First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
dial the phone (use a cell for test run/practice) ...once you hear the
message press "*" (the asterisk key) and enter your 4 digit code (the
default code is 1234 or sometimes 0000) you really should change this,
this might have been done in the initial setup... read your manual for
the exact commands to be use after/during retrieving msg....
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual: http://www.uniden.com/pdf/DCT648-2om.pdf
Call your phone number. After the greeting is finished and you hear the beep to leave a message push 123 on a touch tone phone and you will be given a list of things you can choose to do including listening to messages. 123 is the default security code unless the security code has been changed. Since you dont know how to retrieve messages Im assuming the default security code has never been changed.
If 123 is not the default security code and you dont know what the code is, you can change your code in the setup menu. You get to this by pushing the stop/set button on the answering machine and holding it for a couple of seconds. Since GE doesnt offer a downloadable manual for the 29878GE1 you should probably take a look at the manual for the 29875GE1 which is basically the same model with the addition of a digital message counter. Hope this helps.
You can activate Call Forwarding whenever you want your calls to be
sent to another phone, including a mobile phone. Once activated, all
your calls will be sent to the forwarding number you request. Each time
a call is forwarded, you will hear one short reminder tone on your home
phone, but you will not be able to answer the call from your home
number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
