Question about Sony PlayStation (PS) Console
Re, all i get is a distorted picture of the game screen. I've tried fine tuning the TV around that channel but it doesn't help.
Posted by Amy FIscher on
Anonymous
    Champion:
  • 231 Answers
Hi sounds like the av sender inside the ps could be getting dodgy, have you tried it on another tv?
Posted on Apr 09, 2012
2 Related Answers
Anonymous
SOURCE: My PS2 won't show on the TV
put all wires accordingly girl
Posted on Feb 08, 2009
Anonymous
  • 72 Answers
SOURCE: I have a psp and
Is your PSP updated? It may not be updated enough to be able to play the game. That might be it. Or your UMD drive is not working or broken.
Posted on Sep 04, 2011
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
My Polaroid TV is connected to Virgin yet most channels are pixelated and the tv looks like it needs fine tuning, but i can't. Any help?
on the tv screen menu go to display and reset the a settings the larger the numbers the better the picture --apply and ok
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
1helpful
Bought a 2nd hand N64 & don't know how to set it up on the tv as no instructions.
You now need to find a channel on your TV that ins't used for anything else (eg an old vhs player or non-digital tv) then whilst on that channel you need to go into your TV's menu, there is often a button both on the remote and TV itself for this. This is where you turn on your N64 if you haven't already. You then will need to go onto automatic tuning (or if you prefer, manual tuning, in the programme section (if you dont have a programme section, just srcoll through each section till you find automatic tuning) your TV should then start to search for channels, after a little while of searching it should find the N64's frequency it may be a terrible picture that is mostly fuzz you can either carry on the tuning to see if it'll find it better or just head straight to fine tuning (if you decied to keep going you can still fine tune for the best picture quality possible and also if the TV doesn't find it just follow the previous steps till it locates the N64 again) once fine tuned you will need to store this new channel and then you can go ahead and enjoy countless hours of fun on the worlds best gaming console. (If the automatic tuning doesn't find the N64 at all try manual tuning). If you have any other issue with the console itself just drop me an e-mail at [email protected] Hope I was a help.
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Can't hook up a game system to a magnovox 13mt143/17 13" tv
You can, but you'll need an RF converter (also called a modulator) to do it. The TV doesn't have a/v input jacks and can only tune in signals coming in at the antenna connector. The converter takes the audio and video signals from the game console and generates a TV signal on channel 3 or 4 which the set can tune in. Unfortunately, this reduces the picture and sound quality somewhat, but it's the only option for your TV. RF converters are available at most large retailers and online, usually in the $15 to $30 range.
1helpful
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
SONY KV-27FV310 FINE TUNING
AUTO PROGRAM YOUR CHANNELS. IF PROBLEM PERSISTS REPAIR OR REPLACE TUNER.
Open Questions:
See all Sony PlayStation (PS) Console Questions
Sony PlayStation (PS) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Muzahura Frank
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
