Question about Philips Televison & Video
After retune bbc redbutton not working
Retune usung buttons on the side got 230 digi services but no bbc red button channel 301 works
Tech Head
    New Friend:
  • 7 Answers
Found this when my Philips LCD TV lost the BBC RED button http://sparedparts.com/parts/details/philips-lcd-tv-bbc-red-button-no-longer-works
No BBC RED button
Posted on May 18, 2012
5 Related Answers
Anonymous
SOURCE: Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Posted on Nov 14, 2008
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: Samsung LE32R7 in DTV mode stays on BBC1
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Posted on Oct 02, 2009
Anonymous
  • 630 Answers
SOURCE: Panasonic Viera retune problem
Make sure that you do a new install retune not an update the channels have moved around a lot
Posted on Oct 24, 2009
Anonymous
  • 53 Answers
SOURCE: Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Posted on Nov 07, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: I have a samsung LCD TV LE27S7 32 in I think and
cable company moved them do a rescan of your channels
Posted on Nov 18, 2009
The bbc red button service on humax listing not working
You should scan for channels again, as some were changed recently.
Sep 14, 2014 | Humax FOXAT HDR DTV Receiver
No sound on iplayer on tvonics z500hd
Workaround procedure to get this to work 1. Go to BBC1. 2. Go to the Guide and select channel 200 - BBC Red Button. Press OK. 3. Exit the Guide and wait. You should see a notice about the BBC Red Button Service. Wait a few seconds. 4. Press the RED button - the display switches to BBC1 and shows the standard (Text) Red Button Index. 5. Press the BLUE button to close the Index. The display shows the BBC1 video and sound. 6. Press the RED button to get into the Red Button Menu. 7. Wait a few seconds and then select the BBC iPlayer. I gained access to the iPlayer once this way yesterday and twice so far today but when I went straight to the iPlayer from BBC1 I lost the sound. I've just shutdown and then re-started the HD500 and successfully accessed the iPlayer using the above method. Note, that if it doesn't work then just switch your box into standby, wait 15 minutes or until the Hard Disk stops and then you can switch it on again. No mains power-off or reset is required.
Mar 29, 2013 | TVonics Televison & Video
After retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Nov 06, 2009 | Pace Televison & Video
I have tried retuning digi box and now i have no bbc channels what do i do next have tried rebooting it and it makes no difference also tried at least 12 times to retune still get no bbc channels
Your question is posted under the heading Sagem PVR 6280 so I'll assume that's the model which you have.
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune.
Seethe address below for a chart of affected models, but the officialadvice is that you must contact Sagem directly on 0845 0900 316 foreither an over the air update or an update DVD depending upon themanufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
SorryI can't provide you with a definite solution but I hope that I've atleast reassured you that it's not something which you have or haven'tdone!
Please return the favour by rating my answer.
Oct 04, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Loss of BBC channels
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Philips TV Tuner Video Capture PCI Card -...
I have a technika lcd19dvdid307 tv and a universal remote. How do O re tune for new digital channels? I have lost the original remote. Thank you, kellyanne
I think the point he is making is that he only has a universal remote - not the original, so the problem isn't not being able to find the channels, but not being able to select the retune option in the first place. I have same problem - the remotes that shipped with this TV were rubbish (I have gone through 2!) and some buttons stop working. The retune / setup memu is seperate to the other basic set-up stuff and many universal remotes don't have theis 'other' button. Best solution, get a replacement remote that is MADE to work with this TV then you can auto-tune to your hearts content.
Sep 11, 2009 | Insignia NS-LCD19 19 in. LCD TV
Tuning grundig tv - tp623
Using ACP (Auto Channel Programming) Press and keep button P/C pressed for approx 3 sec. ACP and the channel number appear on the screen. Indications in red letters are activated. Press button< YES is activated.
Screen will display SEARCH - STORE YES< > NO
Once you have the channel you want, activate STORE then <YES
This instuction booklet covers P40,P45 and P50 with remote model tp623
Sep 22, 2007 | Televison & Video
Televison & Video Logo
325 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
