SOURCE: camcorder
Here is the link for the manual if you need it; http://books.jvcservice.com/download/686501845/13178.pdf Page 29 shows the connections for video output to a tv or vcr so either of these configurations would work to a video capture card installed in your pc (please ask again if you need more info on these cards - a quick walk round your local computer shop should give you an idea, and they will also have the necessary cables.) Hope this helps :)
SOURCE: User Guide
Hi - You can download the manual by clicking the link underlined in blue below:
GR-SXM330U
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: WE NEED THE OPERATING MANUAL FOR THE JVC COMPACT
The operating manual could be downloaded from here
http://resources.jvc.com/Resources/00/00/91/LYT1519-001A.pdf
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: how to hook up jvc gr-amx18u vhs-c analog camcorder
I use a Dazzle transfer box via it's UBS port. I think I payed $85 bucks for it. BestBuy.
SOURCE: I want to get the video on my JVC GR-AXM17U VHS-C
Software, Cables. Thats about it. There are a couple of ways to do it. If your JVC has a USB port & cable then using the software that came with the camera, OR downloaded from the manufacturers web site, install that, THEN connect the camera up, most likely it will show up as a "Drive" then you should be able to simply Copy & Paste your files as normal. Then once on PC you can manipulate them however you want. IF you have Composite Video & Audio OUT on JVC, and you have some method of getting Video & Audio INTO your PC, then you can also use this, Plug it all in, start your "Recording" software, then Press Play on JVC, You can get USB Video input dongles, 7 or, some video cards allow Video IN too.
Testimonial: "Thanks! That will work"
