You need a preamp to solve that problem, the older amps and receivers had built in phono inputs with a preamp stage. Radio Shack use to make a preamp that ran on a 9volt battery for turntables that ran into the very problem you are talking about. But I do not know if they are still available, go to www.ebay.com Type: turntable or turntable preamp
SOURCE: Bose Cinemate Home Theater
same prob, the tech was no help wants me to send in 75 bucks and pay for the shipping
SOURCE: Bose Cinemate home theatre
My Bose will not turn on. I know I have power because the red led light is on. The remote works fine with my TV. It worked a couple of days ago and now it seems like the signal from the remote is not going through the reciaver.
SOURCE: remote control codes for a Bose Cinemate
I would contact ur nearest Bose dealer or Contact the company through the website to get a replacement remote, you will of course need the serial number for the product when you contact them, using a universal remote can make things easier but you will not be able to access most of the functions without the original
SOURCE: Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
SOURCE: code for Bose cinemate surround system
We just got a Bose Cinemate system and have the same issue - none of the listed codes for the Synergy V work.
Has anybody got this to work yet?
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
